跳转到主内容
HP 15-ef2025nr Fan Replacement
你所需要的
  1. HP 15-ef2025nr Fan Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the laptop upside down with the hinge facing you.
  2. HP 15-ef2025nr Fan Replacement: 步骤 2 中的图像 1,2 HP 15-ef2025nr Fan Replacement: 步骤 2 中的图像 2,2
    • Use an opening tool to remove the rubber strips by prying up a corner and gently pulling off the strip.
  3. HP 15-ef2025nr Fan Replacement: 步骤 3 中的图像 1,2 HP 15-ef2025nr Fan Replacement: 步骤 3 中的图像 2,2
    • Use a Phillips screwdriver to remove the eight 3 mm screws (including the 2 screws that were not under the rubber strips) securing the lower case.
  4. HP 15-ef2025nr Fan Replacement: 步骤 4 中的图像 1,2 HP 15-ef2025nr Fan Replacement: 步骤 4 中的图像 2,2
    • Flip the laptop over and open the lid.
    • Insert an opening tool into the seam between the edge of the lower case and the chassis.
    • Gently pry around the entire perimeter until the lower case separates from the chassis.
    • Close the lid and flip the laptop back over.
    • Remove the lower case.
  5. HP 15-ef2025nr Fan Replacement: 步骤 5 中的图像 1,3 HP 15-ef2025nr Fan Replacement: 步骤 5 中的图像 2,3 HP 15-ef2025nr Fan Replacement: 步骤 5 中的图像 3,3
    • Remove the five 2 mm Phillips screws holding the battery down.
    • Take care not to puncture, bend, or twist the battery. Lithium batteries can be very volatile. Follow all proper hazardous disposal laws where you live.
    • Gently lift the front edge of the battery up to disconnect the socket.
    • Lift the battery up and out.
  6. HP 15-ef2025nr Fan Replacement, Fan: 步骤 6 中的图像 1,3 HP 15-ef2025nr Fan Replacement, Fan: 步骤 6 中的图像 2,3 HP 15-ef2025nr Fan Replacement, Fan: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use tweezers to pull the fan connector directly out of its motherboard socket.
    • Do not pull on the wires; they are very delicate.
  7. HP 15-ef2025nr Fan Replacement: 步骤 7 中的图像 1,3 HP 15-ef2025nr Fan Replacement: 步骤 7 中的图像 2,3 HP 15-ef2025nr Fan Replacement: 步骤 7 中的图像 3,3
    • Remove the three 2 mm Phillips screws at the top corners and four o'clock position on the fan.
    • Remove the fan.
结论
kyle mccomas
于02/13/23注册
291 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 16
总计 179
