跳转到主内容
HP 15-dy2024nr Fan Assembly Replacement
你所需要的
  1. HP 15-dy2024nr Fan Assembly Replacement, Back Cover: 步骤 1 中的图像 1,2 HP 15-dy2024nr Fan Assembly Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Use a spudger to peel one corner of each of the rubber feet from the bottom of the laptop.
    • Gently peel the feet from the laptop using the spudger revealing the screws underneath.
    • If the rubber foot peels away but leaves adhesive behind you must peel the adhesive away before removing the screws.
  2. HP 15-dy2024nr Fan Assembly Replacement: 步骤 2 中的图像 1,3 HP 15-dy2024nr Fan Assembly Replacement: 步骤 2 中的图像 2,3 HP 15-dy2024nr Fan Assembly Replacement: 步骤 2 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove:
    • Two 2.5mm x 6mm screws
    • Six 2mm x 6mm screws
    • Be sure to keep different screw sizes separated.
  3. HP 15-dy2024nr Fan Assembly Replacement: 步骤 3 中的图像 1,3 HP 15-dy2024nr Fan Assembly Replacement: 步骤 3 中的图像 2,3 HP 15-dy2024nr Fan Assembly Replacement: 步骤 3 中的图像 3,3
    • Insert an iFixit opening tool into the seam between the keyboard area and bottom cover.
    • Using another iFixit opening tool, slide along the seam to unhook the clips.
    • There are clips all the way around the seam. You may hear a popping sound as the clips come loose. This step may require some force to separate the back cover from the laptop.
    • When the front of the laptop is open, you can use your finger to hold a corner open then slide an iFixit opening tool along the seam toward the back corner.
    • After the clips have been released, flip the laptop over and lift the cover.
  4. HP 15-dy2024nr Fan Assembly Replacement, Battery: 步骤 4 中的图像 1,3 HP 15-dy2024nr Fan Assembly Replacement, Battery: 步骤 4 中的图像 2,3 HP 15-dy2024nr Fan Assembly Replacement, Battery: 步骤 4 中的图像 3,3
    • Remove five 2.0mm x 3.0mm screws using a Phillips #00 screwdriver.
    • Use the iFixit opening picks to lift the battery away from the laptop.
  5. HP 15-dy2024nr Fan Assembly Replacement: 步骤 5 中的图像 1,3 HP 15-dy2024nr Fan Assembly Replacement: 步骤 5 中的图像 2,3 HP 15-dy2024nr Fan Assembly Replacement: 步骤 5 中的图像 3,3
    • Be aware that the battery is plugged into the motherboard.
    • Unplug the battery from the motherboard.
    • Lift the battery away from the laptop and remove.
  6. HP 15-dy2024nr Fan Assembly Replacement, Fan Assembly: 步骤 6 中的图像 1,2 HP 15-dy2024nr Fan Assembly Replacement, Fan Assembly: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • If your fan needs to be cleaned, do that now. If it is not working properly, continue with these steps to remove the broken fan.
    • Use the nylon tipped reverse tweezers to lift the cables up from off the motherboard before attempting to disconnect the connector from the motherboard.
    • Do not use the tweezers to pull the cables off the motherboard.
  7. HP 15-dy2024nr Fan Assembly Replacement: 步骤 7 中的图像 1,2 HP 15-dy2024nr Fan Assembly Replacement: 步骤 7 中的图像 2,2
    • Wedge the Halberd spudger between the black plastic connector and the motherboard.
    • Lightly twist the spudger blade up. The connector should pop off.
  8. HP 15-dy2024nr Fan Assembly Replacement: 步骤 8 中的图像 1,3 HP 15-dy2024nr Fan Assembly Replacement: 步骤 8 中的图像 2,3 HP 15-dy2024nr Fan Assembly Replacement: 步骤 8 中的图像 3,3
    • Remove the three chrome-plated 2.0mm x 3.0mm screws holding the fan assembly in place using a Phillips #0 screwdriver.
    • Lift the fan assembly out of the laptop.
结论
另外一个人完成了本指南。
Nathaniel Reeves
于09/27/22注册
366 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 16
总计 202
