跳转到主内容
HP 15-dy2024nr Battery Replacement
你所需要的
  1. HP 15-dy2024nr Battery Replacement, Back Cover: 步骤 1 中的图像 1,2 HP 15-dy2024nr Battery Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Use a spudger to peel one corner of each of the rubber feet from the bottom of the laptop.
    • Gently peel the feet from the laptop using the spudger revealing the screws underneath.
    • If the rubber foot peels away but leaves adhesive behind you must peel the adhesive away before removing the screws.
  2. HP 15-dy2024nr Battery Replacement: 步骤 2 中的图像 1,3 HP 15-dy2024nr Battery Replacement: 步骤 2 中的图像 2,3 HP 15-dy2024nr Battery Replacement: 步骤 2 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove:
    • Two 2.5mm x 6mm screws
    • Six 2mm x 6mm screws
    • Be sure to keep different screw sizes separated.
  3. HP 15-dy2024nr Battery Replacement: 步骤 3 中的图像 1,3 HP 15-dy2024nr Battery Replacement: 步骤 3 中的图像 2,3 HP 15-dy2024nr Battery Replacement: 步骤 3 中的图像 3,3
    • Insert an iFixit opening tool into the seam between the keyboard area and bottom cover.
    • Using another iFixit opening tool, slide along the seam to unhook the clips.
    • There are clips all the way around the seam. You may hear a popping sound as the clips come loose. This step may require some force to separate the back cover from the laptop.
    • When the front of the laptop is open, you can use your finger to hold a corner open then slide an iFixit opening tool along the seam toward the back corner.
    • After the clips have been released, flip the laptop over and lift the cover.
  4. HP 15-dy2024nr Battery Replacement, Battery: 步骤 4 中的图像 1,3 HP 15-dy2024nr Battery Replacement, Battery: 步骤 4 中的图像 2,3 HP 15-dy2024nr Battery Replacement, Battery: 步骤 4 中的图像 3,3
    • Remove five 2.0mm x 3.0mm screws using a Phillips #00 screwdriver.
    • Use the iFixit opening picks to lift the battery away from the laptop.
  5. HP 15-dy2024nr Battery Replacement: 步骤 5 中的图像 1,3 HP 15-dy2024nr Battery Replacement: 步骤 5 中的图像 2,3 HP 15-dy2024nr Battery Replacement: 步骤 5 中的图像 3,3
    • Be aware that the battery is plugged into the motherboard.
    • Unplug the battery from the motherboard.
    • Lift the battery away from the laptop and remove.
结论
2等其他人完成本指南。
Konnor Young
于09/27/22注册
523 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 34
总计 679
