简介
When replacing any part of the HP 15-dy2024nr, the first step is to remove the back cover. Make sure you have the correct tools before continuing to this guide.
Before removing or replacing any part, be sure that the laptop is powered off. If you're unsure, turn the laptop on, then shut it off from the start menu.
你所需要的
Use a spudger to peel one corner of each of the rubber feet from the bottom of the laptop.
Gently peel the feet from the laptop using the spudger revealing the screws underneath.
Insert an iFixit opening tool into the seam between the keyboard area and bottom cover.
Using another iFixit opening tool, slide along the seam to unhook the clips.
When the front of the laptop is open, you can use your finger to hold a corner open then slide an iFixit opening tool along the seam toward the back corner.
After the clips have been released, flip the laptop over and lift the cover.
另外一个人完成了本指南。
