跳转到主内容
HP 15-da0012dx SSD Replacement
你所需要的
  1. HP 15-da0012dx SSD Replacement, Battery: 步骤 1 中的图像 1,2 HP 15-da0012dx SSD Replacement, Battery: 步骤 1 中的图像 2,2
    • Power down your laptop before proceeding.
    • Turn your laptop over so that the Laptop Identification Tag on the underside of the laptop faces the ceiling.
  2. HP 15-da0012dx SSD Replacement: 步骤 2 中的图像 1,3 HP 15-da0012dx SSD Replacement: 步骤 2 中的图像 2,3 HP 15-da0012dx SSD Replacement: 步骤 2 中的图像 3,3
    • Using the plastic opening tools, peel back the plastic feet from the underside of the laptop.
  3. HP 15-da0012dx SSD Replacement: 步骤 3 中的图像 1,2 HP 15-da0012dx SSD Replacement: 步骤 3 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the eleven 9.0 mm screws holding the back cover in place.
  4. HP 15-da0012dx SSD Replacement: 步骤 4 中的图像 1,2 HP 15-da0012dx SSD Replacement: 步骤 4 中的图像 2,2
    • Slide the optical drive out of the computer.
  5. HP 15-da0012dx SSD Replacement: 步骤 5 中的图像 1,3 HP 15-da0012dx SSD Replacement: 步骤 5 中的图像 2,3 HP 15-da0012dx SSD Replacement: 步骤 5 中的图像 3,3
    • Flip the computer over and open the screen.
    • Start from a corner and run the plastic opening tools along the edge of the back cover.
    • After the cover has been completely loosened around the entire perimeter, close the screen and flip the computer over.
    • Gently pry back the cover starting from the middle, bottom edge.
    • Make sure not to bend or crack the plastic cover.
  6. HP 15-da0012dx SSD Replacement: 步骤 6 中的图像 1,2 HP 15-da0012dx SSD Replacement: 步骤 6 中的图像 2,2
    • Using the Phillips #1 screwdriver, remove the three 8.0 mm screws holding the battery in place.
  7. HP 15-da0012dx SSD Replacement: 步骤 7 中的图像 1,2 HP 15-da0012dx SSD Replacement: 步骤 7 中的图像 2,2
    • Remove the battery by tilting the top of the battery towards you and pulling the battery away from the mounting tabs.
  8. HP 15-da0012dx SSD Replacement, SSD: 步骤 8 中的图像 1,2 HP 15-da0012dx SSD Replacement, SSD: 步骤 8 中的图像 2,2
    • Using the Phillips #1 screwdriver, remove the single 3.0 mm screw holding the SSD module in place.
  9. HP 15-da0012dx SSD Replacement: 步骤 9 中的图像 1,2 HP 15-da0012dx SSD Replacement: 步骤 9 中的图像 2,2
    • Pull the SSD module away from the socket.
结论
5等其他人完成本指南。
Xavier Hung
于02/07/19注册
914 声望
创作了4篇指南
团队
UC Davis, Team S20-G4, Lore Winter 2019 UC Davis, Team S20-G4, Lore Winter 2019 的会员
UCD-LORE-W19S20G4
3 名成员
创作了7篇指南
一条评论
Nice explanation about how to disassemble of hp laptop and assembly of SSD again in this video. Thanks this help me a lot. If you need assistance in Delhi ncr. Kindly call us
Mahima Singh - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 94
总计 8,863
