跳转到主内容
HP 15-da0012dx Motherboard Replacement
你所需要的
  1. HP 15-da0012dx Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 HP 15-da0012dx Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Power down your laptop before proceeding.
    • Turn your laptop over so that the Laptop Identification Tag on the underside of the laptop faces the ceiling.
  2. HP 15-da0012dx Motherboard Replacement: 步骤 2 中的图像 1,3 HP 15-da0012dx Motherboard Replacement: 步骤 2 中的图像 2,3 HP 15-da0012dx Motherboard Replacement: 步骤 2 中的图像 3,3
    • Using the plastic opening tools, peel back the plastic feet from the underside of the laptop.
  3. HP 15-da0012dx Motherboard Replacement: 步骤 3 中的图像 1,2 HP 15-da0012dx Motherboard Replacement: 步骤 3 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the eleven 9.0 mm screws holding the back cover in place.
  4. HP 15-da0012dx Motherboard Replacement: 步骤 4 中的图像 1,2 HP 15-da0012dx Motherboard Replacement: 步骤 4 中的图像 2,2
    • Slide the optical drive out of the computer.
  5. HP 15-da0012dx Motherboard Replacement: 步骤 5 中的图像 1,3 HP 15-da0012dx Motherboard Replacement: 步骤 5 中的图像 2,3 HP 15-da0012dx Motherboard Replacement: 步骤 5 中的图像 3,3
    • Flip the computer over and open the screen.
    • Start from a corner and run the plastic opening tools along the edge of the back cover.
    • After the cover has been completely loosened around the entire perimeter, close the screen and flip the computer over.
    • Gently pry back the cover starting from the middle, bottom edge.
    • Make sure not to bend or crack the plastic cover.
  6. HP 15-da0012dx Motherboard Replacement: 步骤 6 中的图像 1,2 HP 15-da0012dx Motherboard Replacement: 步骤 6 中的图像 2,2
    • Using the Phillips #1 screwdriver, remove the three 8.0 mm screws holding the battery in place.
  7. HP 15-da0012dx Motherboard Replacement: 步骤 7 中的图像 1,2 HP 15-da0012dx Motherboard Replacement: 步骤 7 中的图像 2,2
    • Remove the battery by tilting the top of the battery towards you and pulling the battery away from the mounting tabs.
  8. HP 15-da0012dx Motherboard Replacement, RAM: 步骤 8 中的图像 1,2 HP 15-da0012dx Motherboard Replacement, RAM: 步骤 8 中的图像 2,2
    • Spread the retention clips on either side of the RAM module outward until you hear a click sound.
    • The RAM module should tilt up at a 45 degree angle.
  9. HP 15-da0012dx Motherboard Replacement: 步骤 9 中的图像 1,2 HP 15-da0012dx Motherboard Replacement: 步骤 9 中的图像 2,2
    • Grasp the edge of the RAM module and pull it away from the slot.
    • Follow Steps 8 and 9 to remove both RAM modules.
  10. HP 15-da0012dx Motherboard Replacement, SSD: 步骤 10 中的图像 1,2 HP 15-da0012dx Motherboard Replacement, SSD: 步骤 10 中的图像 2,2
    • Using the Phillips #1 screwdriver, remove the single 3.0 mm screw holding the SSD module in place.
  11. HP 15-da0012dx Motherboard Replacement: 步骤 11 中的图像 1,2 HP 15-da0012dx Motherboard Replacement: 步骤 11 中的图像 2,2
    • Pull the SSD module away from the socket.
  12. HP 15-da0012dx Motherboard Replacement, Motherboard: 步骤 12 中的图像 1,1
    • Using the Phillips #1 Screwdriver, remove the single 3.0 mm screw holding the wifi card and gently pull the wifi card away.
  13. HP 15-da0012dx Motherboard Replacement: 步骤 13 中的图像 1,2 HP 15-da0012dx Motherboard Replacement: 步骤 13 中的图像 2,2
    • Using the Phillips #1 Screwdriver, remove the four 3.0 mm screws holding the heat sink in place.
    • Gently pull the heat sink out of the laptop.
  14. HP 15-da0012dx Motherboard Replacement: 步骤 14 中的图像 1,2 HP 15-da0012dx Motherboard Replacement: 步骤 14 中的图像 2,2
    • Using the Phillips #1 screwdriver, remove the single 3.0 mm screw holding the small circuit board.
    • Gently remove the small circuit board.
  15. HP 15-da0012dx Motherboard Replacement: 步骤 15 中的图像 1,3 HP 15-da0012dx Motherboard Replacement: 步骤 15 中的图像 2,3 HP 15-da0012dx Motherboard Replacement: 步骤 15 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Using the metal tweezers, disconnect the ribbon cables from the motherboard .
    • First remove the USB board cable followed by the keyboard and touchpad cables.
  16. HP 15-da0012dx Motherboard Replacement: 步骤 16 中的图像 1,1
    • Using the Phillips #1 screwdriver, remove the single 3.0 mm screw holding the USB card in place.
    • Gently remove the USB card from the laptop.
  17. HP 15-da0012dx Motherboard Replacement: 步骤 17 中的图像 1,2 HP 15-da0012dx Motherboard Replacement: 步骤 17 中的图像 2,2
    • Remove the speaker cable from the cable holder.
    • Tilt the bottom of the laptop up 30 degrees to move the monitor holders up to allow access to the rest of the laptop, and then return the laptop to its original state.
  18. HP 15-da0012dx Motherboard Replacement: 步骤 18 中的图像 1,2 HP 15-da0012dx Motherboard Replacement: 步骤 18 中的图像 2,2
    • Using the Phillips #1 Screwdriver, remove the 3 mm screw from the motherboard.
    • Carefully remove the motherboard.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 26
总计 2,299
