跳转到主内容
HP 15-da0012dx Battery Replacement
你所需要的
  1. HP 15-da0012dx Battery Replacement, Battery: 步骤 1 中的图像 1,2 HP 15-da0012dx Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Power down your laptop before proceeding.
    • Turn your laptop over so that the Laptop Identification Tag on the underside of the laptop faces the ceiling.
  2. HP 15-da0012dx Battery Replacement: 步骤 2 中的图像 1,3 HP 15-da0012dx Battery Replacement: 步骤 2 中的图像 2,3 HP 15-da0012dx Battery Replacement: 步骤 2 中的图像 3,3
    • Using the plastic opening tools, peel back the plastic feet from the underside of the laptop.
  3. HP 15-da0012dx Battery Replacement: 步骤 3 中的图像 1,2 HP 15-da0012dx Battery Replacement: 步骤 3 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the eleven 9.0 mm screws holding the back cover in place.
  4. HP 15-da0012dx Battery Replacement: 步骤 4 中的图像 1,2 HP 15-da0012dx Battery Replacement: 步骤 4 中的图像 2,2
    • Slide the optical drive out of the computer.
  5. HP 15-da0012dx Battery Replacement: 步骤 5 中的图像 1,3 HP 15-da0012dx Battery Replacement: 步骤 5 中的图像 2,3 HP 15-da0012dx Battery Replacement: 步骤 5 中的图像 3,3
    • Flip the computer over and open the screen.
    • Start from a corner and run the plastic opening tools along the edge of the back cover.
    • After the cover has been completely loosened around the entire perimeter, close the screen and flip the computer over.
    • Gently pry back the cover starting from the middle, bottom edge.
    • Make sure not to bend or crack the plastic cover.
  6. HP 15-da0012dx Battery Replacement: 步骤 6 中的图像 1,2 HP 15-da0012dx Battery Replacement: 步骤 6 中的图像 2,2
    • Using the Phillips #1 screwdriver, remove the three 8.0 mm screws holding the battery in place.
  7. HP 15-da0012dx Battery Replacement: 步骤 7 中的图像 1,2 HP 15-da0012dx Battery Replacement: 步骤 7 中的图像 2,2
    • Remove the battery by tilting the top of the battery towards you and pulling the battery away from the mounting tabs.
结论
6等其他人完成本指南。
Xavier Hung
于02/07/19注册
914 声望
创作了4篇指南
团队
UC Davis, Team S20-G4, Lore Winter 2019 UC Davis, Team S20-G4, Lore Winter 2019 的会员
UCD-LORE-W19S20G4
3 名成员
创作了7篇指南
4条评论
Where to find, buy the same battery.
Divya Lekha - 回复
Where r living. We can help you which website you buy this battery
Mahima Singh -
Thank you for the guide! =D
Kevin - 回复
If you are living in Delhi ncr. We provide him service and delivery of hp ht03xl battery at very reasonable price at your office and home. Our home service executive will help you to assemble this battery. Nice description details about here. How to replace hp original battery.
Mahima Singh - 回复
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 36
过去 30 天: 159
总计 13,408
