跳转到主内容
HP 15-da0002dx SSD Replacement
你所需要的
  1. HP 15-da0002dx SSD Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Make sure the computer is completely turned off.
  2. HP 15-da0002dx SSD Replacement: 步骤 2 中的图像 1,1
    • Turn over the laptop.
    • The HP label should be touching the table and the bottom cover should be facing up.
  3. HP 15-da0002dx SSD Replacement: 步骤 3 中的图像 1,2 HP 15-da0002dx SSD Replacement: 步骤 3 中的图像 2,2
    • Two plastic feet are located on adjacent sides of the back cover.
    • Peel back the plastic feet using the plastic opening tools.
  4. HP 15-da0002dx SSD Replacement: 步骤 4 中的图像 1,1
    • Using the Phillips #1 screwdriver, unscrew the eleven 9.0 mm screws holding the back cover in place.
  5. HP 15-da0002dx SSD Replacement: 步骤 5 中的图像 1,1
    • Carefully flip over the computer so the HP label is now facing the ceiling.
  6. HP 15-da0002dx SSD Replacement: 步骤 6 中的图像 1,2 HP 15-da0002dx SSD Replacement: 步骤 6 中的图像 2,2
    • Open the screen.
    • Run the plastic opening tools along the edge of the back cover. Do this until the back cover becomes loose.
  7. HP 15-da0002dx SSD Replacement: 步骤 7 中的图像 1,1
    • Close the screen and flip over the laptop. Using the plastic opening tools, gently take off the back cover starting from the middle, bottom edge.
  8. HP 15-da0002dx SSD Replacement, Battery: 步骤 8 中的图像 1,1
    • Remove the screws holding the battery in place using a Phillips #1 screwdriver.
  9. HP 15-da0002dx SSD Replacement: 步骤 9 中的图像 1,2 HP 15-da0002dx SSD Replacement: 步骤 9 中的图像 2,2
    • Using your fingers, tilt the top part of the battery towards you.
    • Continue to pull the rest of the battery away from the mounting tabs to remove.
  10. HP 15-da0002dx SSD Replacement, SSD: 步骤 10 中的图像 1,1
    • Remove the screw holding the SSD in place using the Phillips #1 screwdriver.
  11. HP 15-da0002dx SSD Replacement: 步骤 11 中的图像 1,1
    • Carefully pull the SSD away from the socket.
结论
2等其他人完成本指南。
一条评论
sir
can we add a hdd of 1tb also without replacing ssd???
Kranti Ajit - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 25
总计 2,066
