跳转到主内容
HP 15-da0002dx Fan Replacement
你所需要的
  1. HP 15-da0002dx Fan Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Make sure the computer is completely turned off.
  2. HP 15-da0002dx Fan Replacement: 步骤 2 中的图像 1,1
    • Turn over the laptop.
    • The HP label should be touching the table and the bottom cover should be facing up.
  3. HP 15-da0002dx Fan Replacement: 步骤 3 中的图像 1,2 HP 15-da0002dx Fan Replacement: 步骤 3 中的图像 2,2
    • Two plastic feet are located on adjacent sides of the back cover.
    • Peel back the plastic feet using the plastic opening tools.
  4. HP 15-da0002dx Fan Replacement: 步骤 4 中的图像 1,1
    • Using the Phillips #1 screwdriver, unscrew the eleven 9.0 mm screws holding the back cover in place.
  5. HP 15-da0002dx Fan Replacement: 步骤 5 中的图像 1,1
    • Carefully flip over the computer so the HP label is now facing the ceiling.
  6. HP 15-da0002dx Fan Replacement: 步骤 6 中的图像 1,2 HP 15-da0002dx Fan Replacement: 步骤 6 中的图像 2,2
    • Open the screen.
    • Run the plastic opening tools along the edge of the back cover. Do this until the back cover becomes loose.
  7. HP 15-da0002dx Fan Replacement: 步骤 7 中的图像 1,1
    • Close the screen and flip over the laptop. Using the plastic opening tools, gently take off the back cover starting from the middle, bottom edge.
  8. HP 15-da0002dx Fan Replacement, Battery: 步骤 8 中的图像 1,1
    • Remove the screws holding the battery in place using a Phillips #1 screwdriver.
  9. HP 15-da0002dx Fan Replacement: 步骤 9 中的图像 1,2 HP 15-da0002dx Fan Replacement: 步骤 9 中的图像 2,2
    • Using your fingers, tilt the top part of the battery towards you.
    • Continue to pull the rest of the battery away from the mounting tabs to remove.
  10. HP 15-da0002dx Fan Replacement, Fan: 步骤 10 中的图像 1,2 HP 15-da0002dx Fan Replacement, Fan: 步骤 10 中的图像 2,2
    • Hold the fan in place and remove the one 8.0 mm screw from the fan .
  11. HP 15-da0002dx Fan Replacement: 步骤 11 中的图像 1,1
    • Pull out the connector for the fan cable using the opening tool or spudger.
  12. HP 15-da0002dx Fan Replacement: 步骤 12 中的图像 1,1
    • Carefully take out the fan from the computer.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 23
总计 1,383
