跳转到主内容
HP 15-da0002dx Back Cover Replacement
你所需要的
  1. HP 15-da0002dx Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Make sure the computer is completely turned off.
  2. HP 15-da0002dx Back Cover Replacement: 步骤 2 中的图像 1,1
    • Turn over the laptop.
    • The HP label should be touching the table and the bottom cover should be facing up.
  3. HP 15-da0002dx Back Cover Replacement: 步骤 3 中的图像 1,2 HP 15-da0002dx Back Cover Replacement: 步骤 3 中的图像 2,2
    • Two plastic feet are located on adjacent sides of the back cover.
    • Peel back the plastic feet using the plastic opening tools.
  4. HP 15-da0002dx Back Cover Replacement: 步骤 4 中的图像 1,1
    • Using the Phillips #1 screwdriver, unscrew the eleven 9.0 mm screws holding the back cover in place.
  5. HP 15-da0002dx Back Cover Replacement: 步骤 5 中的图像 1,1
    • Carefully flip over the computer so the HP label is now facing the ceiling.
  6. HP 15-da0002dx Back Cover Replacement: 步骤 6 中的图像 1,2 HP 15-da0002dx Back Cover Replacement: 步骤 6 中的图像 2,2
    • Open the screen.
    • Run the plastic opening tools along the edge of the back cover. Do this until the back cover becomes loose.
  7. HP 15-da0002dx Back Cover Replacement: 步骤 7 中的图像 1,1
    • Close the screen and flip over the laptop. Using the plastic opening tools, gently take off the back cover starting from the middle, bottom edge.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 12
过去 30 天: 44
总计 6,097
