跳转到主内容
HP 15-bw0xx Battery Replacement
你所需要的
  1. HP 15-bw0xx Battery Replacement, HP 15-bw0xx Battery: 步骤 1 中的图像 1,3 HP 15-bw0xx Battery Replacement, HP 15-bw0xx Battery: 步骤 1 中的图像 2,3 HP 15-bw0xx Battery Replacement, HP 15-bw0xx Battery: 步骤 1 中的图像 3,3
    • First, start by identifying your laptop. Be sure it is specifically the "HP Laptop 15-bw0xx" model.
    • If you are unsure of the model, turn on your laptop. Then press and hold the "FN" key and the "ESC" key at the same time.
    • The model type is under the title "Product name."
  2. HP 15-bw0xx Battery Replacement: 步骤 2 中的图像 1,1
    • Turn the closed laptop over onto its face, with the hinged side facing away from you.
    • Be sure to unplug your laptop and turn it off before continuing.
  3. HP 15-bw0xx Battery Replacement: 步骤 3 中的图像 1,3 HP 15-bw0xx Battery Replacement: 步骤 3 中的图像 2,3 HP 15-bw0xx Battery Replacement: 步骤 3 中的图像 3,3
    • Place a finger on the top left slider, then push the black piece all the way to the right.
    • A finger grip to slide the hinge lock open lies to the left of a closed padlock symbol. This is how the battery is unlocked or locked in place.
  4. HP 15-bw0xx Battery Replacement: 步骤 4 中的图像 1,3 HP 15-bw0xx Battery Replacement: 步骤 4 中的图像 2,3 HP 15-bw0xx Battery Replacement: 步骤 4 中的图像 3,3
    • Place a finger on the top right slider, then slide the black piece all the way to the left until it clicks out of place.
    • There will be three vertically parallel finger grips on the slider and a small 3/4 full battery symbol to the left of the slider. This slider is what detaches the battery from the laptop.
    • You may need to use a thumb or a little force to complete this step.
  5. HP 15-bw0xx Battery Replacement: 步骤 5 中的图像 1,1
    • Remove the battery from the laptop.
  6. HP 15-bw0xx Battery Replacement: 步骤 6 中的图像 1,3 HP 15-bw0xx Battery Replacement: 步骤 6 中的图像 2,3 HP 15-bw0xx Battery Replacement: 步骤 6 中的图像 3,3
    • Gently line the new battery up to the slot in which you removed the old battery from.
    • Press the battery into the slot until you hear it click into place.
  7. HP 15-bw0xx Battery Replacement: 步骤 7 中的图像 1,3 HP 15-bw0xx Battery Replacement: 步骤 7 中的图像 2,3 HP 15-bw0xx Battery Replacement: 步骤 7 中的图像 3,3
    • Reverse Step #4 in order to safely lock the battery in place.
结论
After completing all of these steps, you will have successfully replaced your HP Laptop 15-bw0xx battery.
3等其他人完成本指南。
一条评论
hello, any idea where I can get a genuine battery for this laptop?
Brian Mwangi - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 51
总计 3,105
