跳转到主内容
HP 15-ba0709dx Back Cover Replacement
你所需要的
  1. HP 15-ba0709dx Back Cover Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the device over and locate the battery compartment.
    • Slide the battery release latch on the left and right side until the battery is detached from its slot.
    • A noticeable pop will be heard when the battery is fully released.
  2. HP 15-ba0709dx Back Cover Replacement: 步骤 2 中的图像 1,1
    • Pull the battery out of its slot.
    • Be careful not to damage any of the connectors in the process.
  3. HP 15-ba0709dx Back Cover Replacement, Back Cover: 步骤 3 中的图像 1,1
    • Place the laptop on a clean, flat surface with the bottom side facing up.
  4. HP 15-ba0709dx Back Cover Replacement: 步骤 4 中的图像 1,1
    • Using a Phillips Head Screwdriver, remove the screws anchoring the bottom casing.
    • Note: Make sure to keep track of the screws once they have been removed.
  5. HP 15-ba0709dx Back Cover Replacement: 步骤 5 中的图像 1,1
    • Locate the screws about 1 inch from the battery release tabs and use a Phillips Head Screwdriver to remove these screws.
    • Note:Place these newly removed screws with the ones removed in Step 2.
  6. HP 15-ba0709dx Back Cover Replacement: 步骤 6 中的图像 1,2 HP 15-ba0709dx Back Cover Replacement: 步骤 6 中的图像 2,2
    • Locate the rubber friction pads on the top corners of the laptop. Pry the pads from the laptop and place them off to the side
    • Removing the friction pads will reveal two more anchoring screws.
    • Note: The adhesive keeping the pads on the laptop will weaken once doing this, but it is necessary to removing the bottom cover of the laptop.
  7. HP 15-ba0709dx Back Cover Replacement: 步骤 7 中的图像 1,1
    • Remove disc reader.
    • Note: If all screws are removed it should slide out easily.
  8. HP 15-ba0709dx Back Cover Replacement: 步骤 8 中的图像 1,2 HP 15-ba0709dx Back Cover Replacement: 步骤 8 中的图像 2,2
    • Use a plastic prod to pry the back cover off the laptop.
    • Be careful not to damage the laptop while prying.
结论
另外一个人完成了本指南。
Lydia Brown
于03/20/17注册
369 声望
创作了2篇指南
团队
Texas Tech, Team S13-G3, Bennett Spring 2017 Texas Tech, Team S13-G3, Bennett Spring 2017 的会员
TTU-BENNETT-S17S13G3
5 名成员
创作了5篇指南
2条评论
Make sure to use a very thin shim, but strong enough to pry.
spotty118 - 回复
thanks- also worked for 15-ba053nr
Renee Brandt - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 1,920
