简介
Use this guide to replace a dead hard drive.
  1. Use Latch on the left to unlock the battery Use Latch on the right to eject the battery Use Latch on the right to eject the battery
    • Use Latch on the left to unlock the battery
    • Use Latch on the right to eject the battery
  2. Remove case screws
    • Remove case screws
    • Ten 8mm Phillips #1
  3. Use prying tool to remove optical drive Use prying tool to remove optical drive
    • Use prying tool to remove optical drive
  4. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  5. Use Uspudger to remove left and right rubber feet Use Uspudger to remove left and right rubber feet Use Uspudger to remove left and right rubber feet
    • Use Uspudger to remove left and right rubber feet
  6. Remove the screws located beneath both rubber feet. Two 8mm Phillips #1
    • Remove the screws located beneath both rubber feet.
    • Two 8mm Phillips #1
  7. Use the prying tool to remove the bottom case. Careful to not damage the clips that hold the bottom case on. I found it easier to start on the opposite side of the hinges.
    • Use the prying tool to remove the bottom case.
    • Careful to not damage the clips that hold the bottom case on.
    • I found it easier to start on the opposite side of the hinges.
  8. Remove screws securing the hard drive bracket Three 3mm Phillips #0 Three 3mm Phillips #0
    • Remove screws securing the hard drive bracket
    • Three 3mm Phillips #0
  9. Use spudger to loosen the SATA connector then disconnect the cable and remove the hard drive. Use spudger to loosen the SATA connector then disconnect the cable and remove the hard drive. Use spudger to loosen the SATA connector then disconnect the cable and remove the hard drive.
    • Use spudger to loosen the SATA connector then disconnect the cable and remove the hard drive.
  10. Remove bracket screws from the hard drive. Four 3mm Phillips #1
    • Remove bracket screws from the hard drive.
    • Four 3mm Phillips #1
    • Make sure, when reassembling, to orient the hard drive correctly in the brackets.
结论
另外一个人完成了本指南。
Joe Severino
于2017年11月07日注册
199 信誉积分
撰写一个指南
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 3
过去的30天: 17
总计 96
