跳转到主内容
HP 15-ay014dx RAM Replacement
你所需要的
  1. HP 15-ay014dx RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Disconnect device from power source and power down.
  2. HP 15-ay014dx RAM Replacement: 步骤 2 中的图像 1,1
    • With the device turned upside down, use your index fingers to push the battery latches in towards each other.
  3. HP 15-ay014dx RAM Replacement: 步骤 3 中的图像 1,1
    • The latch on your left will stay at the inward position, while the latch on the right will slide back out.
    • Gently grasp the battery and pull it back away from the device and yourself.
  4. HP 15-ay014dx RAM Replacement, Optical Drive: 步骤 4 中的图像 1,1
    • Close the laptop and lay it down with the bottom facing up.
    • Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
  5. HP 15-ay014dx RAM Replacement: 步骤 5 中的图像 1,1
    • Grip the optical drive and gently pull it out.
  6. HP 15-ay014dx RAM Replacement, RAM: 步骤 6 中的图像 1,1
    • Remove the 11 screws holding the body of the laptop together with a size #00 Phillips screwdriver.
  7. HP 15-ay014dx RAM Replacement: 步骤 7 中的图像 1,2 HP 15-ay014dx RAM Replacement: 步骤 7 中的图像 2,2
    • Use the spudger to press the tabs in the back of the computer. Carefully remove the back of the laptop by prying around the sides using the plastic opening tool.
  8. HP 15-ay014dx RAM Replacement: 步骤 8 中的图像 1,2 HP 15-ay014dx RAM Replacement: 步骤 8 中的图像 2,2
    • Undo the clips holding the RAM in place using the plastic opening tool.
  9. HP 15-ay014dx RAM Replacement: 步骤 9 中的图像 1,1
    • Carefully pull out the RAM from the motherboard.
结论
7等其他人完成本指南。
Drake Scoville
于09/21/17注册
533 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 9
总计 719
