跳转到主内容
HP 15-ay014dx Optical Drive Replacement
你所需要的
  1. HP 15-ay014dx Optical Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Disconnect device from power source and power down.
  2. HP 15-ay014dx Optical Drive Replacement: 步骤 2 中的图像 1,1
    • With the device turned upside down, use your index fingers to push the battery latches in towards each other.
  3. HP 15-ay014dx Optical Drive Replacement: 步骤 3 中的图像 1,1
    • The latch on your left will stay at the inward position, while the latch on the right will slide back out.
    • Gently grasp the battery and pull it back away from the device and yourself.
  4. HP 15-ay014dx Optical Drive Replacement, Optical Drive: 步骤 4 中的图像 1,1
    • Close the laptop and lay it down with the bottom facing up.
    • Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
  5. HP 15-ay014dx Optical Drive Replacement: 步骤 5 中的图像 1,1
    • Grip the optical drive and gently pull it out.
结论
2等其他人完成本指南。
Colton King
于09/21/17注册
227 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 6
总计 281
