简介
This guide will show you how to safely remove the motherboard from your HP 15-ay014dx laptop.
你所需要的
Close the laptop and lay it down with the bottom facing up.
Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
Remove the highlighted screws holding the body of the laptop together with a size #00 Phillips screwdriver.
Remove the 11 screws holding the body of the laptop together with a size #00 Phillips screwdriver.
Disconnect all ribbon connectors by flipping up the black tabs and gently pulling them out.
Disconnect the speakers by gently pulling the connector out.
Disconnect the Fan by gently pulling the connector out.
Disconnect the power by gently pulling the connectors out.
2等其他人完成本指南。
