跳转到主内容
HP 15-ay014dx Hard Drive Disk Replacement
你所需要的
  1. HP 15-ay014dx Hard Drive Disk Replacement, Battery: 步骤 1 中的图像 1,1
    • Disconnect device from power source and power down.
  2. HP 15-ay014dx Hard Drive Disk Replacement: 步骤 2 中的图像 1,1
    • With the device turned upside down, use your index fingers to push the battery latches in towards each other.
  3. HP 15-ay014dx Hard Drive Disk Replacement: 步骤 3 中的图像 1,1
    • The latch on your left will stay at the inward position, while the latch on the right will slide back out.
    • Gently grasp the battery and pull it back away from the device and yourself.
  4. HP 15-ay014dx Hard Drive Disk Replacement, Optical Drive: 步骤 4 中的图像 1,1
    • Close the laptop and lay it down with the bottom facing up.
    • Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
  5. HP 15-ay014dx Hard Drive Disk Replacement: 步骤 5 中的图像 1,1
    • Grip the optical drive and gently pull it out.
  6. HP 15-ay014dx Hard Drive Disk Replacement, Hard Drive Disk: 步骤 6 中的图像 1,2 HP 15-ay014dx Hard Drive Disk Replacement, Hard Drive Disk: 步骤 6 中的图像 2,2
    • Remove the highlighted screws holding the body of the laptop together with a size #00 Phillips screwdriver.
  7. HP 15-ay014dx Hard Drive Disk Replacement: 步骤 7 中的图像 1,3 HP 15-ay014dx Hard Drive Disk Replacement: 步骤 7 中的图像 2,3 HP 15-ay014dx Hard Drive Disk Replacement: 步骤 7 中的图像 3,3
    • Using the spudger, push in the tabs in the back that hold the body together. Carefully pry the body apart by working the spudger around the body.
    • Pull the back cover off.
  8. HP 15-ay014dx Hard Drive Disk Replacement: 步骤 8 中的图像 1,3 HP 15-ay014dx Hard Drive Disk Replacement: 步骤 8 中的图像 2,3 HP 15-ay014dx Hard Drive Disk Replacement: 步骤 8 中的图像 3,3
    • Pry up on the clamp holding the SATA power ribbon using the plastic opening tool.
    • Pull out the SATA power ribbon using the tweezers.
  9. HP 15-ay014dx Hard Drive Disk Replacement: 步骤 9 中的图像 1,2 HP 15-ay014dx Hard Drive Disk Replacement: 步骤 9 中的图像 2,2
    • Remove the highlighted screws holding the hard drive to the body using the Philips #00 screwdriver.
    • Remove the hard drive.
  10. HP 15-ay014dx Hard Drive Disk Replacement: 步骤 10 中的图像 1,1
    • Remove the 4 screws holding the hard drive to the hard drive cage using the Philips #00 screwdriver.
结论
6等其他人完成本指南。
Jimmy Huynh
于09/26/17注册
263 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 1,919
