跳转到主内容
HP 15-ay011nr Fan Replacement
你所需要的
  1. HP 15-ay011nr Fan Replacement, Battery: 步骤 1 中的图像 1,1
    • Slide the two battery lock latches on the back of the device to the “unlock” position.
  2. HP 15-ay011nr Fan Replacement: 步骤 2 中的图像 1,1
    • Lift the battery upward to remove it from the device.
  3. HP 15-ay011nr Fan Replacement, Back Panel: 步骤 3 中的图像 1,1
    • Using the PH1 phillips-head screwdriver, remove all the 5/16 in. screws from the back of the device.
    • There should be 10 in total, be sure to keep them together!
  4. HP 15-ay011nr Fan Replacement: 步骤 4 中的图像 1,1
    • Locate the optical disc drive and remove it from the device by sliding it straight of the device.
  5. HP 15-ay011nr Fan Replacement: 步骤 5 中的图像 1,2 HP 15-ay011nr Fan Replacement: 步骤 5 中的图像 2,2
    • Covering the hinges of the device are rubber bumpers secured to the device using adhesive. Remove them carefully.
    • Place the adhesive side up as you will need to place them back after your replacement is complete.
  6. HP 15-ay011nr Fan Replacement: 步骤 6 中的图像 1,2 HP 15-ay011nr Fan Replacement: 步骤 6 中的图像 2,2
    • In the same spot you’ve just removed the bumpers from, you will find two 5/16 in. screws. Using the same Phillips-head screwdriver used in step 2, remove the screws
    • Be sure to keep the screws together!
  7. HP 15-ay011nr Fan Replacement: 步骤 7 中的图像 1,1
    • Carefully remove the back panel from the device.
    • If you are unable to do this with your hands, you can use a thin prying tool of your choice to make it easier!
  8. HP 15-ay011nr Fan Replacement, Fan: 步骤 8 中的图像 1,2 HP 15-ay011nr Fan Replacement, Fan: 步骤 8 中的图像 2,2
    • There are two 5/16 in. screws adjacent from each other that secure the fan to the device. Use the PH1 phillips-head screwdriver to remove them.
    • Be sure to keep them together!
  9. HP 15-ay011nr Fan Replacement: 步骤 9 中的图像 1,2 HP 15-ay011nr Fan Replacement: 步骤 9 中的图像 2,2
    • Lift the clear plastic strip holding down the fan and lift the fan out of place.
  10. HP 15-ay011nr Fan Replacement: 步骤 10 中的图像 1,2 HP 15-ay011nr Fan Replacement: 步骤 10 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use your fingers or tweezers to pinch both sides of the connector and remove the fan from the device.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 1,463
