跳转到主内容
HP 15-af013cl Front Facing Camera Replacement
你所需要的
  1. HP 15-af013cl Front Facing Camera Replacement, Battery: 步骤 1 中的图像 1,1
    • Start off by flipping the laptop on its back.
  2. HP 15-af013cl Front Facing Camera Replacement: 步骤 2 中的图像 1,3 HP 15-af013cl Front Facing Camera Replacement: 步骤 2 中的图像 2,3 HP 15-af013cl Front Facing Camera Replacement: 步骤 2 中的图像 3,3
    • Push the two spring-loaded tabs inward.
    • Once unlatched, pull the battery out of its compartment.
  3. HP 15-af013cl Front Facing Camera Replacement, Screen: 步骤 3 中的图像 1,1
    • Flip the laptop over and have it open as you normally would.
  4. HP 15-af013cl Front Facing Camera Replacement: 步骤 4 中的图像 1,3 HP 15-af013cl Front Facing Camera Replacement: 步骤 4 中的图像 2,3 HP 15-af013cl Front Facing Camera Replacement: 步骤 4 中的图像 3,3
    • Using a pry tool, unclip the entire outer plastic cover from the front of the screen.
    • Gently remove the front plastic cover.
  5. HP 15-af013cl Front Facing Camera Replacement: 步骤 5 中的图像 1,1
    • Remove the two 2.5mm × 3.0mm Phillips screws from each corner of the display.
  6. HP 15-af013cl Front Facing Camera Replacement: 步骤 6 中的图像 1,2 HP 15-af013cl Front Facing Camera Replacement: 步骤 6 中的图像 2,2
    • Carefully lift the display out of the laptop shell and flip it on its front.
    • Disconnect the single cable from the back of the display.
  7. HP 15-af013cl Front Facing Camera Replacement, Front Facing Camera: 步骤 7 中的图像 1,2 HP 15-af013cl Front Facing Camera Replacement, Front Facing Camera: 步骤 7 中的图像 2,2
    • The front camera is held in by light adhesive. Pry gently on the back of the camera in order to remove it.
    • Remove the cable from under the metal foil.
  8. HP 15-af013cl Front Facing Camera Replacement: 步骤 8 中的图像 1,1
    • Flip the laptop back over.
    • Using the Phillips P0 screwdriver, remove the 9 M2.5mm x 6.5mm screws from the bottom of the laptop.
    • Remove the additional 2 M2.0mm × 1.5mm Phillips screws located in the battery compartment.
  9. HP 15-af013cl Front Facing Camera Replacement: 步骤 9 中的图像 1,2 HP 15-af013cl Front Facing Camera Replacement: 步骤 9 中的图像 2,2
    • Remove the optical disk drive from the side of the laptop.
  10. HP 15-af013cl Front Facing Camera Replacement: 步骤 10 中的图像 1,1
    • Lift off the bottom cover, exposing the motherboard and other components underneath.
  11. HP 15-af013cl Front Facing Camera Replacement: 步骤 11 中的图像 1,1
    • Disconnect the display ribbon cable from the motherboard.
结论
Stephen Perreira
于09/27/17注册
787 声望
创作了6篇指南
团队
Cal Poly, Team S8-G6, Banghart Fall 2017 Cal Poly, Team S8-G6, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S8G6
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 11
总计 388
