跳转到主内容
HP 15-af013cl AC Adapter Replacement
你所需要的
  1. HP 15-af013cl AC Adapter Replacement, Battery: 步骤 1 中的图像 1,1
    • Start off by flipping the laptop on its back.
  2. HP 15-af013cl AC Adapter Replacement: 步骤 2 中的图像 1,3 HP 15-af013cl AC Adapter Replacement: 步骤 2 中的图像 2,3 HP 15-af013cl AC Adapter Replacement: 步骤 2 中的图像 3,3
    • Push the two spring-loaded tabs inward.
    • Once unlatched, pull the battery out of its compartment.
  3. HP 15-af013cl AC Adapter Replacement, Motherboard: 步骤 3 中的图像 1,1
    • Using the Phillips P0 screwdriver, remove the nine 2.5mm x 6.5mm screws from the bottom of the laptop.
    • Remove the additional two 2.0mm × 1.5mm Phillips screws located in the battery compartment.
  4. HP 15-af013cl AC Adapter Replacement: 步骤 4 中的图像 1,2 HP 15-af013cl AC Adapter Replacement: 步骤 4 中的图像 2,2
    • Remove the optical disk drive from the side of the laptop.
  5. HP 15-af013cl AC Adapter Replacement: 步骤 5 中的图像 1,1
    • Lift off the bottom cover, exposing the motherboard and other components underneath.
  6. HP 15-af013cl AC Adapter Replacement: 步骤 6 中的图像 1,2 HP 15-af013cl AC Adapter Replacement: 步骤 6 中的图像 2,2
    • Begin by removing the 3 Phillips M2.0mm × 10.0mm screws of the processor fan.
    • Disconnect the fan connector from the motherboard.
  7. HP 15-af013cl AC Adapter Replacement: 步骤 7 中的图像 1,1
    • Remove the five Phillips 2.5mm × 6 .5mm screws using the Phillips P0 screwdriver.
  8. HP 15-af013cl AC Adapter Replacement: 步骤 8 中的图像 1,3 HP 15-af013cl AC Adapter Replacement: 步骤 8 中的图像 2,3 HP 15-af013cl AC Adapter Replacement: 步骤 8 中的图像 3,3
    • Disconnect the ribbon cables for the keyboard, display, trackpad and the various system components.
    • Remove the Wi-Fi card and cables.
  9. HP 15-af013cl AC Adapter Replacement: 步骤 9 中的图像 1,1
    • Carefully lift out the motherboard from the laptop.
  10. HP 15-af013cl AC Adapter Replacement, AC Adapter: 步骤 10 中的图像 1,1
    • Remove the 2 M2.0mm × 5.0mm Phillips screws located on the metal screen hinge closest to where the processor fan was.
  11. HP 15-af013cl AC Adapter Replacement: 步骤 11 中的图像 1,3 HP 15-af013cl AC Adapter Replacement: 步骤 11 中的图像 2,3 HP 15-af013cl AC Adapter Replacement: 步骤 11 中的图像 3,3
    • Lift off the metal hinge from the laptop body.
    • Gently pull up on the cable leading to the charging port.
结论
Stephen Perreira
于09/27/17注册
787 声望
创作了6篇指南
团队
Cal Poly, Team S8-G6, Banghart Fall 2017 Cal Poly, Team S8-G6, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S8G6
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 16
总计 688
