跳转到主内容
HP 15-ac142dx Screen Replacement
你所需要的
  1. HP 15-ac142dx Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • The first step you should take is to turn the laptop off.
    • Next you want to get the prying tool and wedge it into the seam of the screen and outer casing.
  2. HP 15-ac142dx Screen Replacement: 步骤 2 中的图像 1,2 HP 15-ac142dx Screen Replacement: 步骤 2 中的图像 2,2
    • Once it is wedged in on one of the upper corners you want to gently lift and slide the tool down the sides and top of the seam until the frame pops off.
    • Continue moving the tool down, while wedged, to release the grasp. You will be left with just the screen in the casing.
    • While prying off make sure you have a good grasp on the computer. You will know it is coming off due to the audible clicks
  3. HP 15-ac142dx Screen Replacement: 步骤 3 中的图像 1,2 HP 15-ac142dx Screen Replacement: 步骤 3 中的图像 2,2
    • Next, you will want to unscrew the Phillips PM2.0×5.2 screws at the top of the screen with the #0 bit, this will allow the screen to pop off easily.
    • Once all the screws are removed, gently remove the screen from the outer casing.
结论
另外一个人完成了本指南。
Nicole Mathieu
于03/19/18注册
620 声望
创作了5篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 593
