跳转到主内容
HP 15-ac142dx Motherboard Battery Replacement
你所需要的
  1. HP 15-ac142dx Motherboard Battery Replacement, Motherboard Battery: 步骤 1 中的图像 1,3 HP 15-ac142dx Motherboard Battery Replacement, Motherboard Battery: 步骤 1 中的图像 2,3 HP 15-ac142dx Motherboard Battery Replacement, Motherboard Battery: 步骤 1 中的图像 3,3
    • Turn off the computer and flip it over onto a flat surface.
    • Remove battery by sliding the battery lock.
    • Remove the 10 screws
  2. HP 15-ac142dx Motherboard Battery Replacement: 步骤 2 中的图像 1,2 HP 15-ac142dx Motherboard Battery Replacement: 步骤 2 中的图像 2,2
    • Flip the computer back over and use the iFixit tool in order to pry the keyboard from the bottom of the computer.
    • Once off you will be able to see the mother board battery.
    • Remove the battery.
    • The battery should be able to be easily removed just by hand
结论
Follow previous instructions in reverse order to reassemble the device .
另外一个人完成了本指南。
Nicole Mathieu
于03/19/18注册
620 声望
创作了5篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 766
