跳转到主内容
HP 15-ac121dx Screen Replacement
你所需要的
  1. HP 15-ac121dx Screen  Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. HP 15-ac121dx Screen  Replacement: 步骤 2 中的图像 1,1
    • Turn off the computer by holding the power button.
  3. HP 15-ac121dx Screen  Replacement: 步骤 3 中的图像 1,2 HP 15-ac121dx Screen  Replacement: 步骤 3 中的图像 2,2
    • To remove the battery, slide the left slider on the back to the unlocked position.
  4. HP 15-ac121dx Screen  Replacement: 步骤 4 中的图像 1,2 HP 15-ac121dx Screen  Replacement: 步骤 4 中的图像 2,2
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
  5. HP 15-ac121dx Screen  Replacement, Screen: 步骤 5 中的图像 1,1
    • Open the laptop so that the screen is facing you.
  6. HP 15-ac121dx Screen  Replacement: 步骤 6 中的图像 1,2 HP 15-ac121dx Screen  Replacement: 步骤 6 中的图像 2,2
    • With the screen facing you, use the plastic opening tool to remove the liner around the screen
  7. HP 15-ac121dx Screen  Replacement: 步骤 7 中的图像 1,1
    • Using a Phillips #000 screwdriver, remove all four 2mm screws in each corner of the screen.
  8. HP 15-ac121dx Screen  Replacement: 步骤 8 中的图像 1,2 HP 15-ac121dx Screen  Replacement: 步骤 8 中的图像 2,2
    • Carefully remove the screen and place it face down on the keyboard.
    • Do not pull the screen away from the front panel assembly, as this would damage the cord connecting the screen to the front panel assembly.
  9. HP 15-ac121dx Screen  Replacement: 步骤 9 中的图像 1,2 HP 15-ac121dx Screen  Replacement: 步骤 9 中的图像 2,2
    • With the screen faced down on the keyboard, remove the grounding tape adhered to the back of the screen.
    • You should see a 36-pin plug underneath the grounding tape.
    • Carefully remove the 36-pin plug, not to damage the grounding tape or the plug.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 773
