跳转到主内容
HP 15-ac121dx RAM Replacement
你所需要的
  1. HP 15-ac121dx RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. HP 15-ac121dx RAM Replacement: 步骤 2 中的图像 1,1
    • Turn off the computer by holding the power button.
  3. HP 15-ac121dx RAM Replacement: 步骤 3 中的图像 1,2 HP 15-ac121dx RAM Replacement: 步骤 3 中的图像 2,2
    • To remove the battery, slide the left slider on the back to the unlocked position.
  4. HP 15-ac121dx RAM Replacement: 步骤 4 中的图像 1,2 HP 15-ac121dx RAM Replacement: 步骤 4 中的图像 2,2
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
  5. HP 15-ac121dx RAM Replacement, Back Panel: 步骤 5 中的图像 1,2 HP 15-ac121dx RAM Replacement, Back Panel: 步骤 5 中的图像 2,2
    • Place the laptop with the back panel facing up and the battery compartment facing away from you.
    • Using a spudger, carefully remove the rubber feet on both sides of the battery compartment.
  6. HP 15-ac121dx RAM Replacement: 步骤 6 中的图像 1,1
    • Using a Phillips #000 screwdriver, remover the ten 7mm screws on the back panel.
    • Using the same screwdriver, remove the two 5mm Phillips #000 screws on both sides of the battery compartment.
  7. HP 15-ac121dx RAM Replacement: 步骤 7 中的图像 1,1
    • With the same orientation as the previous step, locate the bottom left corner.
    • Using a plastic opening tool, carefully pry off and remove the back panel.
  8. HP 15-ac121dx RAM Replacement, RAM: 步骤 8 中的图像 1,1
    • With the back panel removed, orient the laptop with the fan located in the bottom left corner.
    • Locate the RAM card.
  9. HP 15-ac121dx RAM Replacement: 步骤 9 中的图像 1,2 HP 15-ac121dx RAM Replacement: 步骤 9 中的图像 2,2
    • Using your fingers, carefully release the locking devices on both sides of the RAM card by moving them away from each other.
    • The RAM card will pop up to sit at an angle.
    • Carefully remove the RAM card with the same orientation which it sits.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 676
