跳转到主内容
HP 15-ac121dx Motherboard Replacement
你所需要的
  1. HP 15-ac121dx Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. HP 15-ac121dx Motherboard Replacement: 步骤 2 中的图像 1,1
    • Turn off the computer by holding the power button.
  3. HP 15-ac121dx Motherboard Replacement: 步骤 3 中的图像 1,2 HP 15-ac121dx Motherboard Replacement: 步骤 3 中的图像 2,2
    • To remove the battery, slide the left slider on the back to the unlocked position.
  4. HP 15-ac121dx Motherboard Replacement: 步骤 4 中的图像 1,2 HP 15-ac121dx Motherboard Replacement: 步骤 4 中的图像 2,2
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
  5. HP 15-ac121dx Motherboard Replacement, Back Panel: 步骤 5 中的图像 1,3 HP 15-ac121dx Motherboard Replacement, Back Panel: 步骤 5 中的图像 2,3 HP 15-ac121dx Motherboard Replacement, Back Panel: 步骤 5 中的图像 3,3
    • Locate the CD Compartment panel and gently slide it out.
  6. HP 15-ac121dx Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove the back of the laptop by unscrewing the screws shown.
    • Also remove the other 5 Phillips screws lining the back cover.
  7. HP 15-ac121dx Motherboard Replacement: 步骤 7 中的图像 1,3 HP 15-ac121dx Motherboard Replacement: 步骤 7 中的图像 2,3 HP 15-ac121dx Motherboard Replacement: 步骤 7 中的图像 3,3
    • Using the prying tool, wedge it underneath the back of the laptop and do the same all around until the back comes off.
    • Dont forget to unscrew 2 screws under 2 plastic tabs (one on each hing). The lid will not come off without them being removed!
  8. HP 15-ac121dx Motherboard Replacement, Fan: 步骤 8 中的图像 1,3 HP 15-ac121dx Motherboard Replacement, Fan: 步骤 8 中的图像 2,3 HP 15-ac121dx Motherboard Replacement, Fan: 步骤 8 中的图像 3,3
    • Locate the Fan as shown.
    • Pull out the black cable, with four wires attached from its port.
  9. HP 15-ac121dx Motherboard Replacement: 步骤 9 中的图像 1,2 HP 15-ac121dx Motherboard Replacement: 步骤 9 中的图像 2,2
    • Pull out the white cable wire from its port.
    • Unscrew the two black Phillips screws holding in the fan.
  10. HP 15-ac121dx Motherboard Replacement: 步骤 10 中的图像 1,2 HP 15-ac121dx Motherboard Replacement: 步骤 10 中的图像 2,2
    • Remove fan.
    • Unscrew the two screws holding in the fan.
  11. HP 15-ac121dx Motherboard Replacement, CD Compartment: 步骤 11 中的图像 1,3 HP 15-ac121dx Motherboard Replacement, CD Compartment: 步骤 11 中的图像 2,3 HP 15-ac121dx Motherboard Replacement, CD Compartment: 步骤 11 中的图像 3,3
    • Locate the CD Compartment as shown and gently slide it out.
  12. HP 15-ac121dx Motherboard Replacement, Motherboard: 步骤 12 中的图像 1,1
    • Remove the TEN 3mm screws.
    • Remove the ONE 9mm screw.
  13. HP 15-ac121dx Motherboard Replacement: 步骤 13 中的图像 1,2 HP 15-ac121dx Motherboard Replacement: 步骤 13 中的图像 2,2
    • Locate the four ribbon clips.
    • Lift the grey part of the ribbon clips.
    • Pull the ribbon cable out and repeat this step for all four ribbon cables.
    • Also use a spudger and release the TWO cables attaching the hard drive to the motherboard. Another ribbon cable is located where the fan was sitting.
  14. HP 15-ac121dx Motherboard Replacement: 步骤 14 中的图像 1,2 HP 15-ac121dx Motherboard Replacement: 步骤 14 中的图像 2,2
    • Pull out the white cable (contains red and white cable attached to a black support) with wires from its port.
  15. HP 15-ac121dx Motherboard Replacement: 步骤 15 中的图像 1,1
    • Remove the motherboard.
结论
另外一个人完成了本指南。
Onose Aigbe
于01/30/18注册
390 声望
创作了3篇指南
团队
Baylor, Team S1-G2, Johnson Spring 2018 Baylor, Team S1-G2, Johnson Spring 2018 的会员
BU-JOHNSON-S18S1G2
3 名成员
创作了6篇指南
一条评论
Pls can the motherboard of HP - 15 ac-250g5 replacethe board of HP 15 ac-121dx since they have the same body structure.
Emeka Jeffrey - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 1,408
