简介
This guide will teach you how to replace the broken fan in your HP 15-ac121dx laptop to prevent the device from overheating.
  1. Remove all external devices from the computer.
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. Turn off the computer by holding the power button.
    • Turn off the computer by holding the power button.
  3. To remove the battery, slide the left slider on the back to the unlocked position. To remove the battery, slide the left slider on the back to the unlocked position.
    • To remove the battery, slide the left slider on the back to the unlocked position.
  4. Push the right slider inwards. Remove the battery out by pulling straight out and to the right.
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
  5. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  6. Locate the CD Compartment panel and gently slide it out. Locate the CD Compartment panel and gently slide it out. Locate the CD Compartment panel and gently slide it out.
    • Locate the CD Compartment panel and gently slide it out.
  7. Remove the back of the laptop by unscrewing the screws shown.
    • Remove the back of the laptop by unscrewing the screws shown.
    • Also remove the other 5 Phillips screws lining the back cover.
  8. Using the prying tool, wedge it underneath the back of the laptop and do the same all around until the back comes off. Dont forget to unscrew 2 screws under 2 plastic tabs (one on each hing). The lid will not come off without them being removed! Dont forget to unscrew 2 screws under 2 plastic tabs (one on each hing). The lid will not come off without them being removed!
    • Using the prying tool, wedge it underneath the back of the laptop and do the same all around until the back comes off.
    • Dont forget to unscrew 2 screws under 2 plastic tabs (one on each hing). The lid will not come off without them being removed!
  9. Locate the Fan as shown. Pull out the black cable, with four wires attached from its port. Pull out the black cable, with four wires attached from its port.
    • Locate the Fan as shown.
    • Pull out the black cable, with four wires attached from its port.
  10. Pull out the white cable wire from its port. Unscrew the two black Phillips screws holding in the fan.
    • Pull out the white cable wire from its port.
    • Unscrew the two black Phillips screws holding in the fan.
  11. Remove fan. Unscrew the two screws holding in the fan.
    • Remove fan.
    • Unscrew the two screws holding in the fan.
结论
Replace fan. To reassemble your device, follow these instructions in reverse order.
另外一个人完成了本指南。
Onose Aigbe
于2018年01月30日注册
390 信誉积分
创作了3篇指南
团队
Baylor, Team S1-G2, Johnson Spring 2018 Baylor, Team S1-G2, Johnson Spring 2018 的会员
BU-JOHNSON-S18S1G2
3 名成员
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 3
过去的30天: 9
总计 236
