跳转到主内容
加入维修社区 - 创建账户
HP 15-R263DX USB Port Replacement
你所需要的
    1. HP 15-R263DX USB Port Replacement, Battery: 步骤 1 中的图像 1,2 HP 15-R263DX USB Port Replacement, Battery: 步骤 1 中的图像 2,2
      • Eject the battery from the computer by sliding the two clips on the bottom of the computer toward the center of the computer.
      • Slide the battery out as shown in the picture.
      询问修复机器人
      添加评论
    1. HP 15-R263DX USB Port Replacement, Optical Drive: 步骤 2 中的图像 1,2 HP 15-R263DX USB Port Replacement, Optical Drive: 步骤 2 中的图像 2,2
      • Using a Phillips #1 screwdriver, remove the small screw next to the disc engraving shown in the picture.
      询问修复机器人
      添加评论
    2. HP 15-R263DX USB Port Replacement: 步骤 3 中的图像 1,1
      • Gently slide the optical drive out of the side of the computer.
      询问修复机器人
      添加评论
    1. HP 15-R263DX USB Port Replacement, HP 15-R263DX Disassembly: 步骤 4 中的图像 1,2 HP 15-R263DX USB Port Replacement, HP 15-R263DX Disassembly: 步骤 4 中的图像 2,2
      • Locate the two corner grips on the hinge side of the computer.
      • Using a metal spudger, remove the two corner grips to reveal the screws.
      询问修复机器人
      添加评论
    2. HP 15-R263DX USB Port Replacement: 步骤 5 中的图像 1,1
      • Remove the 11 small screws on the bottom of the computer that are shown in the picture.
      询问修复机器人
      添加评论
    3. HP 15-R263DX USB Port Replacement: 步骤 6 中的图像 1,1
      • Remove the 2 small screws that are on the bottom side of the disc tray slot.
      • These screws are shorter and wider than the others.
      询问修复机器人
      添加评论
    4. HP 15-R263DX USB Port Replacement: 步骤 7 中的图像 1,2 HP 15-R263DX USB Port Replacement: 步骤 7 中的图像 2,2
      • Once the keyboard is loose, do not immediately pull away from computer. It is attached by the ribbon connector.
      • Using a spudger, pry around the edges of the keyboard until all clips are disengaged and the keyboard is loose from the computer.
      • To disconnect the ribbon connector, flip up the black clip shown in the picture.
      • Gently pull the ribbon until disconnected.
      添加评论
    5. HP 15-R263DX USB Port Replacement: 步骤 8 中的图像 1,2 HP 15-R263DX USB Port Replacement: 步骤 8 中的图像 2,2
      • Disconnect the other two ribbon connectors underneath the keyboard by fliping up the black clips.
      • Remove the 4 small screws shown in the picture.
      询问修复机器人
      添加评论
    6. HP 15-R263DX USB Port Replacement: 步骤 9 中的图像 1,1
      • Disengage the face plate clips by prying the case away from around the outer edge of the face plate with a metal wedge.
      • The face plate can then be lifted away from the computer.
      询问修复机器人
      添加评论
    1. HP 15-R263DX USB Port Replacement, Hard Drive: 步骤 10 中的图像 1,1
      • Remove the 2 black screws holding the hard drive to the computer frame.
      询问修复机器人
      添加评论
    2. HP 15-R263DX USB Port Replacement: 步骤 11 中的图像 1,2 HP 15-R263DX USB Port Replacement: 步骤 11 中的图像 2,2
      • Gently slide the hard drive away from the motherboard to disconnect it.
      • After it's disconnected, lift the hard drive up to remove it from the computer.
      询问修复机器人
      添加评论
    1. HP 15-R263DX USB Port Replacement, USB Port: 步骤 12 中的图像 1,1
      • Remove the single screw holding the USB ports and chip into the computer.
      询问修复机器人
      添加评论
    2. HP 15-R263DX USB Port Replacement: 步骤 13 中的图像 1,1
      • Remove the chip by gently pulling it up and then away from the edge of the case.
      询问修复机器人
      添加评论
    3. HP 15-R263DX USB Port Replacement: 步骤 14 中的图像 1,1
      • Under the motherboard, disconnect the wire that runs to the USB chip.
      • You may need to pull or wedge the wire up from the case as a section of it is glued down.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Drake Hort
于03/05/18注册
487 声望
创作了3篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 24
总计 816
