跳转到主内容
HP 15-AF131DX Wireless Network Card Replacement
你所需要的
  1. HP 15-AF131DX Wireless Network Card Replacement, Battery: 步骤 1 中的图像 1,2 HP 15-AF131DX Wireless Network Card Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the computer upside down on a level surface.
    • Slide the battery lock to unlock the battery.
    • Slide the battery release latch. The latch will click when the battery is released.
    • Lift the battery from the middle to remove it from the computer.
    • The latch will click again when a battery is reinstalled. Switch the battery lock back to locked after reinstalling a battery to keep it secure.
  2. HP 15-AF131DX Wireless Network Card Replacement, Optical Drive: 步骤 2 中的图像 1,2 HP 15-AF131DX Wireless Network Card Replacement, Optical Drive: 步骤 2 中的图像 2,2
    • Using a small Phillips screwdriver, remove the Phillips screw in the middle of the bottom of the computer.
    • Pull the CD/DVD drive outward to slide it away from the computer.
  3. HP 15-AF131DX Wireless Network Card Replacement: 步骤 3 中的图像 1,1
    • To open the drive use an unbent paperclip and press it into the small hole until the disc tray releases.
    • Pull the disc tray out from the front until it is as far as it will go out of the optical drive.
  4. HP 15-AF131DX Wireless Network Card Replacement: 步骤 4 中的图像 1,3 HP 15-AF131DX Wireless Network Card Replacement: 步骤 4 中的图像 2,3 HP 15-AF131DX Wireless Network Card Replacement: 步骤 4 中的图像 3,3
    • To remove excess parts from the optical drive press down on the plastic tab behind the tray's bezel.
    • Gently pry the bezel from the face of the optical drive.
    • With a smaller phillips head screwdriver, remove the screws on the back of the drive, then remove the small metal bracket.
  5. HP 15-AF131DX Wireless Network Card Replacement, Wireless Network Card: 步骤 5 中的图像 1,2 HP 15-AF131DX Wireless Network Card Replacement, Wireless Network Card: 步骤 5 中的图像 2,2
    • The first step of this process is to peel off two rubber feet from the bottom of the laptop.
    • Then remove twelve 8.8 mm screws using the Phillips #0 Screwdriver.
  6. HP 15-AF131DX Wireless Network Card Replacement: 步骤 6 中的图像 1,3 HP 15-AF131DX Wireless Network Card Replacement: 步骤 6 中的图像 2,3 HP 15-AF131DX Wireless Network Card Replacement: 步骤 6 中的图像 3,3
    • Remove the bottom of the plastic case using a blue plastic opening tool.
    • The HP Wireless Network Card is found in Picture 3, circled in red.
  7. HP 15-AF131DX Wireless Network Card Replacement: 步骤 7 中的图像 1,3 HP 15-AF131DX Wireless Network Card Replacement: 步骤 7 中的图像 2,3 HP 15-AF131DX Wireless Network Card Replacement: 步骤 7 中的图像 3,3
    • Remove one 3.3 mm screw using Phillips #0 screwdriver.
    • Pop off the connection wire by pulling the wire upwards off the stud on the HP Wireless Network Card.
    • Pull out the HP Wireless Network Card.
结论
另外一个人完成了本指南。
团队
IUPUI, Team S2-G2, Harley Fall 2018 IUPUI, Team S2-G2, Harley Fall 2018 的会员
IUPUI-HARLEY-F18S2G2
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 620
