跳转到主内容
HP 15-AF131DX Optical Drive Replacement
你所需要的
  1. HP 15-AF131DX Optical Drive Replacement, Optical Drive: 步骤 1 中的图像 1,2 HP 15-AF131DX Optical Drive Replacement, Optical Drive: 步骤 1 中的图像 2,2
    • Using a small Phillips screwdriver, remove the Phillips screw in the middle of the bottom of the computer.
    • Pull the CD/DVD drive outward to slide it away from the computer.
  2. HP 15-AF131DX Optical Drive Replacement: 步骤 2 中的图像 1,1
    • To open the drive use an unbent paperclip and press it into the small hole until the disc tray releases.
    • Pull the disc tray out from the front until it is as far as it will go out of the optical drive.
  3. HP 15-AF131DX Optical Drive Replacement: 步骤 3 中的图像 1,3 HP 15-AF131DX Optical Drive Replacement: 步骤 3 中的图像 2,3 HP 15-AF131DX Optical Drive Replacement: 步骤 3 中的图像 3,3
    • To remove excess parts from the optical drive press down on the plastic tab behind the tray's bezel.
    • Gently pry the bezel from the face of the optical drive.
    • With a smaller phillips head screwdriver, remove the screws on the back of the drive, then remove the small metal bracket.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team S6-G2, Banghart Fall 2017 Cal Poly, Team S6-G2, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S6G2
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 472
