跳转到主内容
HP 15-AF131DX Hard Drive Replacement
你所需要的
  1. HP 15-AF131DX Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,2 HP 15-AF131DX Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 2,2
    • Use a Phillips screwdriver to remove the 10 visible screws on the bottom.
    • Peel up the rubber feet near the hinges.
    • Remove the screw under each.
  2. HP 15-AF131DX Hard Drive Replacement: 步骤 2 中的图像 1,2 HP 15-AF131DX Hard Drive Replacement: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    购买
    • Turn the computer over and use a plastic card, opening pick, or opening tool to pry the space between the keyboard and bottom surface of the computer.
    • Work plastic card, opening pick, or opening tool carefully around the three edges (excluding the side with the screen, which should be positioned at 90 degrees.
    • Gently lift the top surface of the bottom half of the laptop, revealing the hard drive.
  3. HP 15-AF131DX Hard Drive Replacement: 步骤 3 中的图像 1,3 HP 15-AF131DX Hard Drive Replacement: 步骤 3 中的图像 2,3 HP 15-AF131DX Hard Drive Replacement: 步骤 3 中的图像 3,3
    • Remove the three screws that hold the hard drive in place.
    • Lift the hard drive slightly and disconnect the SATA hard drive connector to free the hard drive.
    • Remove the hard drive.
结论
8等其他人完成本指南。
Anthony Martinez
于10/05/17注册
526 声望
创作了3篇指南
团队
Cal Poly, Team S6-G2, Banghart Fall 2017 Cal Poly, Team S6-G2, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S6G2
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 24
总计 5,381
