简介
If the touchpad of your HP 14-dq0060nr is not functioning properly, use this guide to replace your touchpad board.
The touchpad board allows the user to easily navigate the user interface by controlling the mouse cursor. A faulty touchpad board may prevent the user from clicking, scrolling, or may be laggy, jumpy and unresponsive.
Before using this replacement guide, make sure that the drivers are updated and try plugging in a USB mouse or using the HP 14-dq0060nr's touchscreen feature to troubleshoot touchpad issues.
Before beginning, make sure to power off your device completely and disconnect from any external power source.
你所需要的
Flip the laptop over so the backside is facing up.
Use a spudger to remove the grips from the back case to reveal screws underneath.
Use the tip of a spudger to lift the bar holding the touchpad cable in place, then disconnect the touchpad cable.
