跳转到主内容
HP 14-dq0060nr Battery Replacement
你所需要的
  1. HP 14-dq0060nr Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the laptop over so the backside is facing up.
    • Make sure the device is shutoff and unplugged from the AC adapter. Be sure to keep track of which grip goes on which side, as one is larger than the other.
    • Use a spudger to remove the grips from the back case to reveal screws underneath.
    • Be careful when peeling the grips off so they don't tear apart. You need to reuse them them.
  2. HP 14-dq0060nr Battery Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove six 6.0 mm screws and two 4.0 mm Phillips #1 screws.
    • Slide a plastic opening tool underneath the back case near the screen hinges. Gently pry up on either side.
    • You may hear popping sounds as the tabs securing the case release. This is normal. If the case does not move, try prying at a different angle/position.
  3. HP 14-dq0060nr Battery Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove the four, 3.00 mm screws.
  4. HP 14-dq0060nr Battery Replacement: 步骤 4 中的图像 1,1
    • Pull the battery cable away from the connector in the same direction that the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • Remove the battery from the laptop frame.
结论
Christopher Supek
于02/02/23注册
193 声望
创作了2篇指南
团队
Gateway, Team 1-1, Pee Spring 2023 Gateway, Team 1-1, Pee Spring 2023 的会员
GCC-PEE-S23S1G1
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 22
总计 119
