跳转到主内容
HP 14-dq0051dx Charging Port Replacement
你所需要的
  1. HP 14-dq0051dx Charging Port Replacement, Back Case: 步骤 1 中的图像 1,2 HP 14-dq0051dx Charging Port Replacement, Back Case: 步骤 1 中的图像 2,2
    • Turn the laptop upside down so the backside is facing up.
    • Use a Phillips #1 screwdriver to remove eight screws from the back case.
  2. HP 14-dq0051dx Charging Port Replacement: 步骤 2 中的图像 1,1
    • Turn the laptop over and open the screen.
    • Insert the opening tool into the seam between the bottom panel and the keyboard.
    • Run the opening tool along the entire seam to separate the bottom panel.
    • You may hear clicking as you release the taps that secure the case.
  3. HP 14-dq0051dx Charging Port Replacement: 步骤 3 中的图像 1,1
    • Once the bottom panel is separated from the laptop, carefully close the laptop and turn it upside down.
    • Place both your hands on opposite ends of the bottom panel, and lift up and remove the panel.
  4. HP 14-dq0051dx Charging Port Replacement, Battery: 步骤 4 中的图像 1,3 HP 14-dq0051dx Charging Port Replacement, Battery: 步骤 4 中的图像 2,3 HP 14-dq0051dx Charging Port Replacement, Battery: 步骤 4 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove the four 2.5 mm screws that secure the battery.
    • Remove the battery from the laptop.
  5. HP 14-dq0051dx Charging Port Replacement, Charging Port: 步骤 5 中的图像 1,3 HP 14-dq0051dx Charging Port Replacement, Charging Port: 步骤 5 中的图像 2,3 HP 14-dq0051dx Charging Port Replacement, Charging Port: 步骤 5 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove the two 4.5 mm screws from the left hinge.
    • Rotate the hinge up and out of the way.
  6. HP 14-dq0051dx Charging Port Replacement: 步骤 6 中的图像 1,3 HP 14-dq0051dx Charging Port Replacement: 步骤 6 中的图像 2,3 HP 14-dq0051dx Charging Port Replacement: 步骤 6 中的图像 3,3
    • Pull the charging port cable away from the connector in the same direction as the individual wires to unplug the charge port connector.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • Remove the charging port.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 33
总计 331
