跳转到主内容
加入维修社区 - 创建账户
HP 10 2101 Speaker Replacement
你所需要的
  1. HP 10 2101 Speaker Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Identify the SD card port.
  2. HP 10 2101 Speaker Replacement: 步骤 2 中的图像 1,1
    • Insert the smallest plastic opening tool into the SD card port. Gently pry until the back panel separates from the screen panel.
    • Do not insert opening tool too far. Avoid making contact with the metal inside the port.
  3. HP 10 2101 Speaker Replacement: 步骤 3 中的图像 1,1
    • Slide the opening tool along the seam between the back panel and the screen panel, prying the panels apart as you move around the edges.
  4. HP 10 2101 Speaker Replacement: 步骤 4 中的图像 1,1
    • Separate the back panel from the rest of the device.
  5. HP 10 2101 Speaker Replacement, Speakers: 步骤 5 中的图像 1,1
    • Remove the pieces of black tape that hold the speaker wires to the battery.
  6. HP 10 2101 Speaker Replacement: 步骤 6 中的图像 1,2 HP 10 2101 Speaker Replacement: 步骤 6 中的图像 2,2
    • Use the Phillips #00 screwdriver to remove the 4mm screws from the speaker.
    • There are two screws holding both speakers to the plastic device frame.
  7. HP 10 2101 Speaker Replacement: 步骤 7 中的图像 1,1
    • Desolder the speaker wires from the motherboard.
  8. HP 10 2101 Speaker Replacement: 步骤 8 中的图像 1,1
    • Separate the speakers from the device.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 261
