跳转到主内容
HMDX Jam Rubber Battery Cover Replacement
你所需要的
  1. HMDX Jam Rubber Battery Cover Replacement, Rubber Base: 步骤 1 中的图像 1,1
    • Pry off the rubber cover at the bottom of the speaker by using the plastic opening tool.
  2. HMDX Jam Rubber Battery Cover Replacement: 步骤 2 中的图像 1,1
    • Slowly peel the rubber cover off.
  3. HMDX Jam Rubber Battery Cover Replacement: 步骤 3 中的图像 1,1
    • After completely removing the rubber cover, find a new cover and prepare both it and the device for attachment.
  4. HMDX Jam Rubber Battery Cover Replacement: 步骤 4 中的图像 1,1
    • Carefully replace the old rubber with the new one, being mindful to line the cover up correctly with the outside edge of the device as well as the inner cover.
结论
3等其他人完成本指南。
Blake Rounds
于02/17/15注册
360 声望
撰写一个指南
团队
USF Tampa, Team 1-1, Blackwell Winter 2015 USF Tampa, Team 1-1, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S1G1
4 名成员
创作了2篇指南
一条评论
Thanks a ton for taking the time to consider this obvious, likely possibility, and actually documenting and sharing your work-around solution. It is also is handy because it reminds potential buyers that this cute and otherwise cool and super affordable speaker, while a real natural stocking stuffer, might be one of those cheapo gifts that I think a lot of us are getting sick of: fun to get, fun to use, and a downer when you throw away three weeks later. So maybe they made a bad decision on just one part, the sticky part. Customers are pretty cool about understanding that things happen when you try something new. But The fact that this article exists suggests they made a choice not to offer reasonable after purchase support, like I don’t know 10 bucks for a set of Sticky backs? Sure they’re cheap, so don’t hold it a ripoff, and theres probably a market for people who have a need for a short term hrowaway. Anyway you get the gist, and I should pay more attention to the fricking website name.
Legal Labs - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 6,416
