跳转到主内容
HMDX Jam Plus Speaker Replacement
你所需要的
  1. HMDX Jam Plus Speaker Replacement, Battery: 步骤 1 中的图像 1,3 HMDX Jam Plus Speaker Replacement, Battery: 步骤 1 中的图像 2,3 HMDX Jam Plus Speaker Replacement, Battery: 步骤 1 中的图像 3,3
    • Flip the device over so the bottom is facing up.
    • Use the large plastic opening tool to gently pry the rubber base from the device.
    • Slowly move the plastic opening tool around the edge of the rubber base to separate it from the plastic.
  2. HMDX Jam Plus Speaker Replacement: 步骤 2 中的图像 1,2 HMDX Jam Plus Speaker Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the four black 9mm screws from the device.
  3. HMDX Jam Plus Speaker Replacement: 步骤 3 中的图像 1,2 HMDX Jam Plus Speaker Replacement: 步骤 3 中的图像 2,2
    • Gently separate the base from the rest of the device to reveal the battery and the main board.
  4. HMDX Jam Plus Speaker Replacement: 步骤 4 中的图像 1,3 HMDX Jam Plus Speaker Replacement: 步骤 4 中的图像 2,3 HMDX Jam Plus Speaker Replacement: 步骤 4 中的图像 3,3
    • Carefully use the plastic opening tool to remove the glue around the battery and speaker connectors.
    • Pull gently on the connectors to separate each one from the main board.
    • The battery is connected to board in the red socket and the speaker is connected in the white socket.
  5. HMDX Jam Plus Speaker Replacement: 步骤 5 中的图像 1,3 HMDX Jam Plus Speaker Replacement: 步骤 5 中的图像 2,3 HMDX Jam Plus Speaker Replacement: 步骤 5 中的图像 3,3
    • Batteries can be very dangerous if punctured. Use extra caution when using tools around the battery.
    • Use the plastic opening tool to gently pry the battery free from the rest of the device.
  6. HMDX Jam Plus Speaker Replacement: 步骤 6 中的图像 1,2 HMDX Jam Plus Speaker Replacement: 步骤 6 中的图像 2,2
    • Use new adhesive to secure battery back to the rest of the device.
  7. HMDX Jam Plus Speaker Replacement, Speaker: 步骤 7 中的图像 1,2 HMDX Jam Plus Speaker Replacement, Speaker: 步骤 7 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the four black 9mm screws from device.
  8. HMDX Jam Plus Speaker Replacement: 步骤 8 中的图像 1,1
    • Use the plastic opening tool to pry the glue away from the wire. Be careful not to damage the wire.
  9. HMDX Jam Plus Speaker Replacement: 步骤 9 中的图像 1,2 HMDX Jam Plus Speaker Replacement: 步骤 9 中的图像 2,2
    • Use the plastic opening tool to separate the center plastic piece from the rest of the device.
    • Gently lift the center plastic piece and feed the speaker wire through the hole.
  10. HMDX Jam Plus Speaker Replacement: 步骤 10 中的图像 1,2 HMDX Jam Plus Speaker Replacement: 步骤 10 中的图像 2,2
    • Use the plastic opening tool to separate the speaker grate from the rest of the device.
  11. HMDX Jam Plus Speaker Replacement: 步骤 11 中的图像 1,2 HMDX Jam Plus Speaker Replacement: 步骤 11 中的图像 2,2
    • Carefully remove the speaker through the top of the device.
    • Apply new adhesive to the edge of the replacement speaker and the edge of the speaker grate to ensure they do not wiggle loose.
结论
另外一个人完成了本指南。
团队
Montana Tech, Team 10-3, Shirk Fall 2015 Montana Tech, Team 10-3, Shirk Fall 2015 的会员
MTUM-SHIRK-F15S10G3
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 1,397
