跳转到主内容
HMDX Jam Plus Battery Replacement
你所需要的
  1. HMDX Jam Plus Battery Replacement, Battery: 步骤 1 中的图像 1,3 HMDX Jam Plus Battery Replacement, Battery: 步骤 1 中的图像 2,3 HMDX Jam Plus Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Flip the device over so the bottom is facing up.
    • Use the large plastic opening tool to gently pry the rubber base from the device.
    • Slowly move the plastic opening tool around the edge of the rubber base to separate it from the plastic.
  2. HMDX Jam Plus Battery Replacement: 步骤 2 中的图像 1,2 HMDX Jam Plus Battery Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the four black 9mm screws from the device.
  3. HMDX Jam Plus Battery Replacement: 步骤 3 中的图像 1,2 HMDX Jam Plus Battery Replacement: 步骤 3 中的图像 2,2
    • Gently separate the base from the rest of the device to reveal the battery and the main board.
  4. HMDX Jam Plus Battery Replacement: 步骤 4 中的图像 1,3 HMDX Jam Plus Battery Replacement: 步骤 4 中的图像 2,3 HMDX Jam Plus Battery Replacement: 步骤 4 中的图像 3,3
    • Carefully use the plastic opening tool to remove the glue around the battery and speaker connectors.
    • Pull gently on the connectors to separate each one from the main board.
    • The battery is connected to board in the red socket and the speaker is connected in the white socket.
  5. HMDX Jam Plus Battery Replacement: 步骤 5 中的图像 1,3 HMDX Jam Plus Battery Replacement: 步骤 5 中的图像 2,3 HMDX Jam Plus Battery Replacement: 步骤 5 中的图像 3,3
    • Batteries can be very dangerous if punctured. Use extra caution when using tools around the battery.
    • Use the plastic opening tool to gently pry the battery free from the rest of the device.
  6. HMDX Jam Plus Battery Replacement: 步骤 6 中的图像 1,2 HMDX Jam Plus Battery Replacement: 步骤 6 中的图像 2,2
    • Use new adhesive to secure battery back to the rest of the device.
结论
4等其他人完成本指南。
团队
Montana Tech, Team 10-3, Shirk Fall 2015 Montana Tech, Team 10-3, Shirk Fall 2015 的会员
MTUM-SHIRK-F15S10G3
4 名成员
创作了4篇指南
5条评论
Where may battery be purchased?
Thanks,
zappenfusen
warnsdorff - 回复
Where to purchase battery for hmdx jam speaker
Frank David -
Where can a battery be purchased?
robertwacker - 回复
What kind (especifications) that battery?
vecchio.farias - 回复
Where to buy battery for HMDX JAM.Bluetooth speaker
Frank David - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 27
总计 7,122
