跳转到主内容
加入维修社区 - 创建账户
HMDX Jam Plus Micro USB Jack Replacement
你所需要的
  1. HMDX Jam Plus  Micro USB Jack Replacement, Battery: 步骤 1 中的图像 1,3 HMDX Jam Plus  Micro USB Jack Replacement, Battery: 步骤 1 中的图像 2,3 HMDX Jam Plus  Micro USB Jack Replacement, Battery: 步骤 1 中的图像 3,3
    • Flip the device over so the bottom is facing up.
    • Use the large plastic opening tool to gently pry the rubber base from the device.
    • Slowly move the plastic opening tool around the edge of the rubber base to separate it from the plastic.
  2. HMDX Jam Plus  Micro USB Jack Replacement: 步骤 2 中的图像 1,2 HMDX Jam Plus  Micro USB Jack Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the four black 9mm screws from the device.
  3. HMDX Jam Plus  Micro USB Jack Replacement: 步骤 3 中的图像 1,2 HMDX Jam Plus  Micro USB Jack Replacement: 步骤 3 中的图像 2,2
    • Gently separate the base from the rest of the device to reveal the battery and the main board.
  4. HMDX Jam Plus  Micro USB Jack Replacement: 步骤 4 中的图像 1,3 HMDX Jam Plus  Micro USB Jack Replacement: 步骤 4 中的图像 2,3 HMDX Jam Plus  Micro USB Jack Replacement: 步骤 4 中的图像 3,3
    • Carefully use the plastic opening tool to remove the glue around the battery and speaker connectors.
    • Pull gently on the connectors to separate each one from the main board.
    • The battery is connected to board in the red socket and the speaker is connected in the white socket.
  5. HMDX Jam Plus  Micro USB Jack Replacement: 步骤 5 中的图像 1,3 HMDX Jam Plus  Micro USB Jack Replacement: 步骤 5 中的图像 2,3 HMDX Jam Plus  Micro USB Jack Replacement: 步骤 5 中的图像 3,3
    • Batteries can be very dangerous if punctured. Use extra caution when using tools around the battery.
    • Use the plastic opening tool to gently pry the battery free from the rest of the device.
  6. HMDX Jam Plus  Micro USB Jack Replacement: 步骤 6 中的图像 1,2 HMDX Jam Plus  Micro USB Jack Replacement: 步骤 6 中的图像 2,2
    • Use new adhesive to secure battery back to the rest of the device.
  7. HMDX Jam Plus  Micro USB Jack Replacement, Micro USB Jack: 步骤 7 中的图像 1,2 HMDX Jam Plus  Micro USB Jack Replacement, Micro USB Jack: 步骤 7 中的图像 2,2
    • Remove the three black 6mm screws from the main board using a Philips #00 screwdriver.
  8. HMDX Jam Plus  Micro USB Jack Replacement: 步骤 8 中的图像 1,2 HMDX Jam Plus  Micro USB Jack Replacement: 步骤 8 中的图像 2,2
    • Carefully lift the main board away from the plastic.
    • Lift the side with the buttons first and be careful not to damage the Line In Jack or the Micro USB Jack.
  9. HMDX Jam Plus  Micro USB Jack Replacement: 步骤 9 中的图像 1,1
    在这个步骤中使用的工具:
    • Use the Micro soldering iron to heat up each pad and use the desoldering wick to wick up the melted solder.
    • The surface mount jack should pull from the surface without much force. Use tweezers to apply upward pressure on on the jack.
    • Do not apply too much heat to the board as it may damage other portions of the board.
结论
团队
Montana Tech, Team 10-3, Shirk Fall 2015 Montana Tech, Team 10-3, Shirk Fall 2015 的会员
MTUM-SHIRK-F15S10G3
4 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 930
