跳转到主内容
HMDX Jam Battery Replacement
你所需要的
  1. HMDX Jam Battery Replacement, Opening speaker: 步骤 1 中的图像 1,1
    • Use the plastic opening tool to pry off the rubber cover at the bottom of the speaker.
  2. HMDX Jam Battery Replacement, remove rubber cover: 步骤 2 中的图像 1,1
    • Gently remove the rubber cover to expose the screws. If necessary, poke holes through the glue residue to expose the screw heads.
  3. HMDX Jam Battery Replacement, Remove screws: 步骤 3 中的图像 1,1
    • Once you have exposed the screws, use a #1 Phillips screwdriver to remove the four 9 mm screws.
    • It would be wise to use a magnetic mat for the screws for safekeeping.
  4. HMDX Jam Battery Replacement, Exposing Battery: 步骤 4 中的图像 1,1
    • Once you've removed the screws, open the case slowly. The battery is covered in blue packaging.
  5. HMDX Jam Battery Replacement, Removing Battery: 步骤 5 中的图像 1,1
    • Very gently remove the battery from the motherboard.
  6. HMDX Jam Battery Replacement, Remove battery attachments: 步骤 6 中的图像 1,2 HMDX Jam Battery Replacement, Remove battery attachments: 步骤 6 中的图像 2,2
    • Use a solder gun to remove the battery attachments from the motherboard.
结论
41等其他人完成本指南。
团队
USF Tampa, Team 1-1, Blackwell Winter 2015 USF Tampa, Team 1-1, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S1G1
4 名成员
创作了2篇指南
18条评论
Looks like a great solution to fixing the speaker with a battery with a short life span. But what's the amperage of the lithium barberry and where can I purchase one ?
Stephen Lavizzo - 回复
Did you ever find out where to purchase a new battery for it?
DJ Ethics -
Hey Stephen. Can you tell me where i can buy a replacement battery for my P120
Lynchfield Daniel -
On my Model: HX-P240A
KANYO 383541P 3.7V
520mAh 1.924Wh
534114364A17142
minhngoctruong - 回复
My Bluetooth speaker just has a rubber suction on the bottom. There is no area to replace a battery. Is there any way to reset I?
bdale46 - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 39
过去 30 天: 154
总计 95,271
