简介
Use this guide to replace the charging board in your HMD Fusion phone.
The charging board includes the USB-C port and headphone jack. To replace either of the ports, you must replace the entire board.
If you're having issues charging your phone, connecting headphones via the 3.5 mm jack, or if either port is loose, it may be time to replace the charging board.
你所需要的
Unplug all cables from your phone and completely power it down.
Firmly press a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the left edge of your phone until the tray ejects.
Remove the SIM card tray.
Use a T3 Torx screwdriver to remove the sixteen 5.0 mm‑long screws securing the back cover.
Use your fingernails, or angled tweezers, to remove any stuck screws.
Flip your phone over so the screen is facing up.
Insert the tip of an opening pick between the back cover and frame at the SIM card tray cutout.
Use a spudger to pry up and disconnect the power button press connector.
Remove the back cover.
Use a T3 Torx screwdriver to remove the three 3.4 mm‑long screws securing the loudspeaker.
Use your fingers to lift the loudspeaker out of the frame by its metal bracket.
Remove the loudspeaker.
Slide one arm of a pair of tweezers under the metal neck of the black antenna cable's connector head, near the center of the board.
Lift straight up to disconnect the cable.
Repeat for the white antenna cable.
Use a T3 Torx screwdriver to remove the 3.3 mm‑long screw securing the charging board.
The top edge of the charging board is adhered to the frame.
Insert the flat end of a spudger under the top left edge of the charging board, next to the antenna cable connectors.
Slide the spudger under the charging board to separate the adhesive.
1指南评论
If i have tried to fix the phone by self-repair but the phone still not working, where or who i need to refer?
