跳转到主内容
加入维修社区 - 创建账户
HMD Fusion Battery Replacement
你所需要的
    1. HMD Fusion Battery Replacement, Prepare your phone for disassembly: 步骤 1 中的图像 1,1
      • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
      • Unplug all cables from your phone and completely power it down.
      询问修复机器人
      添加评论
    1. HMD Fusion Battery Replacement, Remove the SIM card tray: 步骤 2 中的图像 1,3 HMD Fusion Battery Replacement, Remove the SIM card tray: 步骤 2 中的图像 2,3 HMD Fusion Battery Replacement, Remove the SIM card tray: 步骤 2 中的图像 3,3
      • Firmly press a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the left edge of your phone until the tray ejects.
      • Remove the SIM card tray.
      询问修复机器人
      添加评论
    1. HMD Fusion Battery Replacement, Remove the back cover screws: 步骤 3 中的图像 1,3 HMD Fusion Battery Replacement, Remove the back cover screws: 步骤 3 中的图像 2,3 HMD Fusion Battery Replacement, Remove the back cover screws: 步骤 3 中的图像 3,3
      • Use a T3 Torx screwdriver to remove the sixteen 5.0 mm‑long screws securing the back cover.
      • Use your fingernails, or angled tweezers, to remove any stuck screws.
      • The screws are secured tightly in the back cover, so you might not be able to remove all of them. If you can't remove a few screws, don't worry! Move to the next step and follow the guide normally.
      添加评论
    2. HMD Fusion Battery Replacement: 步骤 4 中的图像 1,1
      在这个步骤中使用的工具:
      Magnetic Project Mat
      $19.95
      • During the next four steps, the remaining back cover screws might fall out unexpectedly.
      • To avoid losing screws, you can place a tray, bowl, or Magnetic Project Mat under the phone while you work.
      询问修复机器人
      添加评论
    3. HMD Fusion Battery Replacement, Unclip the back cover: 步骤 5 中的图像 1,2 HMD Fusion Battery Replacement, Unclip the back cover: 步骤 5 中的图像 2,2
      • Flip your phone over so the screen is facing up.
      • Insert the tip of an opening pick between the back cover and frame at the SIM card tray cutout.
      询问修复机器人
      添加评论
    4. HMD Fusion Battery Replacement: 步骤 6 中的图像 1,3 HMD Fusion Battery Replacement: 步骤 6 中的图像 2,3 HMD Fusion Battery Replacement: 步骤 6 中的图像 3,3
      • Slide the opening pick along the left edge to begin unclipping the back cover.
      询问修复机器人
      添加评论
    5. HMD Fusion Battery Replacement: 步骤 7 中的图像 1,3 HMD Fusion Battery Replacement: 步骤 7 中的图像 2,3 HMD Fusion Battery Replacement: 步骤 7 中的图像 3,3
      • Continue sliding the pick around the perimeter of your phone until the back cover is fully unclipped.
      • The corners can be tricky to unclip and may take some force. If you're having trouble, try prying up with the pick.
      • Don't try to fully remove the cover yet, as it's still connected by a delicate cable.
      询问修复机器人
      添加评论
    6. HMD Fusion Battery Replacement: 步骤 8 中的图像 1,3 HMD Fusion Battery Replacement: 步骤 8 中的图像 2,3 HMD Fusion Battery Replacement: 步骤 8 中的图像 3,3
      • Carefully flip your phone over so the back cover is facing up.
      • Lift the back cover off the frame and flip it over the left edge of your phone, laying the cover flat on your work surface.
      • Be very careful not to strain the back cover's delicate cable.
      • During reassembly, place the back cover onto the frame and firmly press around the perimeter to reengage all the clips.
      询问修复机器人
      添加评论
    7. HMD Fusion Battery Replacement, Disconnect the battery: 步骤 9 中的图像 1,3 HMD Fusion Battery Replacement, Disconnect the battery: 步骤 9 中的图像 2,3 HMD Fusion Battery Replacement, Disconnect the battery: 步骤 9 中的图像 3,3
      询问修复机器人
      添加评论
    8. HMD Fusion Battery Replacement, Disconnect the power button: 步骤 10 中的图像 1,3 HMD Fusion Battery Replacement, Disconnect the power button: 步骤 10 中的图像 2,3 HMD Fusion Battery Replacement, Disconnect the power button: 步骤 10 中的图像 3,3
      • Use a spudger to pry up and disconnect the power button press connector.
      • Remove the back cover.
      添加评论
    1. HMD Fusion Battery Replacement, Remove the battery: 步骤 11 中的图像 1,3 HMD Fusion Battery Replacement, Remove the battery: 步骤 11 中的图像 2,3 HMD Fusion Battery Replacement, Remove the battery: 步骤 11 中的图像 3,3
      • Be very careful not to bend, crease, or puncture the battery during the next few steps. A damaged battery can leak dangerous chemicals and catch fire.
      • Use your fingers to carefully peel the three plastic tabs from the right side of the battery.
      询问修复机器人
      添加评论
    2. HMD Fusion Battery Replacement: 步骤 12 中的图像 1,3 HMD Fusion Battery Replacement: 步骤 12 中的图像 2,3 HMD Fusion Battery Replacement: 步骤 12 中的图像 3,3
      • With one hand, fold the two outer tabs out of the way of the battery and firmly hold them down to secure the frame.
      • If you're having trouble with the tabs, you can fold them under the phone and tape them to the screen.
      • With your free hand, grip the center pull tab and pull straight up to fully separate the battery adhesive.
      • Lay the battery over the left edge of your phone.
      询问修复机器人
      添加评论
    3. HMD Fusion Battery Replacement: 步骤 13 中的图像 1,3 HMD Fusion Battery Replacement: 步骤 13 中的图像 2,3 HMD Fusion Battery Replacement: 步骤 13 中的图像 3,3
      • Use your fingers to peel the battery's plastic film from the frame.
      • Remove the battery and its film.
      询问修复机器人
      添加评论
    4. HMD Fusion Battery Replacement, Remove the battery adhesive: 步骤 14 中的图像 1,3 HMD Fusion Battery Replacement, Remove the battery adhesive: 步骤 14 中的图像 2,3 HMD Fusion Battery Replacement, Remove the battery adhesive: 步骤 14 中的图像 3,3
      • Use tweezers, or your fingers, to peel the three battery adhesive strips off the frame.
      询问修复机器人
      添加评论
    5. HMD Fusion Battery Replacement, Apply the new battery adhesive: 步骤 15 中的图像 1,2 HMD Fusion Battery Replacement, Apply the new battery adhesive: 步骤 15 中的图像 2,2
      • Align the new battery adhesive over the frame, making sure that the three adhesive strips overlap properly.
      询问修复机器人
      添加评论
    6. HMD Fusion Battery Replacement: 步骤 16 中的图像 1,3 HMD Fusion Battery Replacement: 步骤 16 中的图像 2,3 HMD Fusion Battery Replacement: 步骤 16 中的图像 3,3
      • Peel off the clear liner from the new battery adhesive.
      • Align an edge of the adhesive with the textured surface on the frame and press it down flat.
      询问修复机器人
      添加评论
    7. HMD Fusion Battery Replacement: 步骤 17 中的图像 1,3 HMD Fusion Battery Replacement: 步骤 17 中的图像 2,3 HMD Fusion Battery Replacement: 步骤 17 中的图像 3,3
      • Use the flat end of a spudger or your fingers to press the adhesive onto the frame.
      询问修复机器人
      添加评论
    8. HMD Fusion Battery Replacement: 步骤 18 中的图像 1,3 HMD Fusion Battery Replacement: 步骤 18 中的图像 2,3 HMD Fusion Battery Replacement: 步骤 18 中的图像 3,3
      • Grip the middle pull tab on the larger blue liner and peel it off the adhesive.
      • You have to remove this liner first, as it sits on top of the other two liners.
      询问修复机器人
      添加评论
    9. HMD Fusion Battery Replacement: 步骤 19 中的图像 1,3 HMD Fusion Battery Replacement: 步骤 19 中的图像 2,3 HMD Fusion Battery Replacement: 步骤 19 中的图像 3,3
      • Remove the two remaining liners to expose the adhesive.
      询问修复机器人
      添加评论
    10. HMD Fusion Battery Replacement, Replace the battery: 步骤 20 中的图像 1,3 HMD Fusion Battery Replacement, Replace the battery: 步骤 20 中的图像 2,3 HMD Fusion Battery Replacement, Replace the battery: 步骤 20 中的图像 3,3
      • While holding the battery over its recess, temporarily reconnect the battery connector.
      • Lay the battery into its recess.
      询问修复机器人
      添加评论
    11. HMD Fusion Battery Replacement: 步骤 21 中的图像 1,2 HMD Fusion Battery Replacement: 步骤 21 中的图像 2,2
      • Firmly press the battery into its recess to secure it with the adhesive.
      询问修复机器人
      添加评论
结论
To reassemble your device, follow these instructions in reverse order starting with this step.
For optimal performance, calibrate your newly installed battery after reassembling your phone.
取消:我没有完成这个指南。
另外一个人完成了本指南。
Alex Diaz-Kokaisl
于01/16/22注册
247,513 声望
创作了1,203篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了79,118篇指南
1指南评论
A clear and thorough guide through a process that is complete lunacy for a phone that purports to be easily repairable.
Zakalwe - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 47
过去 30 天: 195
总计 6,762
