简介
Use this guide to replace a cracked or damaged back cover on your HMD Fusion phone.
你所需要的
Firmly press a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the left edge of your phone until the tray ejects.
Remove the SIM card tray.
Use a T3 Torx screwdriver to remove the sixteen 5.0 mm‑long screws securing the back cover.
Use your fingernails, or angled tweezers, to remove any stuck screws.
Flip your phone over so the screen is facing up.
Insert the tip of an opening pick between the back cover and frame at the SIM card tray cutout.
Use a spudger to pry up and disconnect the power button press connector.
Remove the back cover.
Use the tip of a spudger to lift the two rubber arms securing the power button out of their slots in the back cover.
