跳转到主内容
HKC P886A Digitizer Replacement
你所需要的
  1. HKC P886A Digitizer Replacement, Disassembling HKC P886A Overall Device Disassembly: 步骤 1 中的图像 1,2 HKC P886A Digitizer Replacement, Disassembling HKC P886A Overall Device Disassembly: 步骤 1 中的图像 2,2
    • Insert the flat tip of the metal spudger into the seam between the back panel and the screen.
    • The easiest insertion point for the metal spudger is at the corners of the device.
    • Slide the spudger across the perimeter of the device and gently pry apart at each corner.
    • When the screen is separated from the back panel there will be two connected ribbon cables between the two halves of the device. These cables must be disconnected before further disassembly.
    • After the pressure clamps are released orient the device so that the speaker is to the right and the screen is tilted away from you.
  2. HKC P886A Digitizer Replacement: 步骤 2 中的图像 1,2 HKC P886A Digitizer Replacement: 步骤 2 中的图像 2,2
    • The device is oriented with the camera to the right and the external button towards the top of the picture.
    • Locate the shorter ribbon cable and the black pressure tabs that hold the ribbon cable in place.
    • The tabs used to connect the ribbon cables are fragile and can easily be damaged.
    • Use the plastic spudger to gently slide the tabs about 2mm away from connector.
    • Once tabs are successfully disconnected the ribbon cable should come out of the port without resistance.
  3. HKC P886A Digitizer Replacement: 步骤 3 中的图像 1,3 HKC P886A Digitizer Replacement: 步骤 3 中的图像 2,3 HKC P886A Digitizer Replacement: 步骤 3 中的图像 3,3
    • Locate the longer ribbon cable and the pressure clamp that holds the cable in the connection port.
    • Using the plastic spudger, flip the black locking clip up.
    • The pressure clip will click when it has been disengaged.
    • Once the clip is unlocked, the cable should slide out without resistance
    • In photo 1 the device is oriented with the camera to the left and external buttons towards the bottom. In photo 2 the device is oriented with the camera toward the user. In photo 3 the camera is to the left.
  4. HKC P886A Digitizer Replacement, Digitizer: 步骤 4 中的图像 1,2 HKC P886A Digitizer Replacement, Digitizer: 步骤 4 中的图像 2,2
    • The matrix is the component that is attached to the LCD (component with the silver backing). It is the component that interprets the location of the users touch.
    • The matrix and screen assembly are delicate and require gentle prying. Try not to deform the components in order to avoid damage to the components.
    • Gently bend screen around LCD to disengage the pressure clamps.
    • Once all pressure clamps are disengaged, separate the LCD screen from the matrix with out touching the display portion of either component.
    • Replacement touch screens are available from this link: laptopscreen.com
  5. HKC P886A Digitizer Replacement: 步骤 5 中的图像 1,1
    • To reattach the matrix to the screen, seat the LCD screen in the pressure clamps and gently push the matrix down to re-engage the clamps.
    • Do not touch the front panel of either device or finger prints and smudges will be on the display.
结论
另外一个人完成了本指南。
Cassidy
于03/11/15注册
409 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 348
