跳转到主内容
HKC P776A Screen Replacement
你所需要的
  1. HKC P776A Screen Replacement, Separating Digitizer and Case: 步骤 1 中的图像 1,1
    • Insert the plastic opening tool between the digitizer and the case.
    • Place the spudger in the gap created by the plastic opening tool to assist in separation.
  2. HKC P776A Screen Replacement: 步骤 2 中的图像 1,2 HKC P776A Screen Replacement: 步骤 2 中的图像 2,2
    • Slide the spudger along the perimeter of the device to fully separate the two pieces.
  3. HKC P776A Screen Replacement, Separating the Screen and Digitizer: 步骤 3 中的图像 1,2 HKC P776A Screen Replacement, Separating the Screen and Digitizer: 步骤 3 中的图像 2,2
    • Use your fingers to pop the screen out from the digitizer.
  4. HKC P776A Screen Replacement, Removing the Optical Cord from the Motherbaord: 步骤 4 中的图像 1,1
    • With the plastic opening tool, lift the black latch up.
  5. HKC P776A Screen Replacement: 步骤 5 中的图像 1,1
    • Pull the optical cord out from the motherboard.
结论
Spencer Pheasant
于01/20/15注册
301 声望
创作了3篇指南
团队
USF Tampa, Team 7-6, Remmell Winter 2015 USF Tampa, Team 7-6, Remmell Winter 2015 的会员
USFT-REMMELL-W15S7G6
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 232
