跳转到主内容
HKC P776A Digitizer Replacement
你所需要的
  1. HKC P776A Digitizer Replacement, Separating Digitizer and Case: 步骤 1 中的图像 1,1
    • Insert the plastic opening tool between the digitizer and the case.
    • Place the spudger in the gap created by the plastic opening tool to assist in separation.
  2. HKC P776A Digitizer Replacement: 步骤 2 中的图像 1,2 HKC P776A Digitizer Replacement: 步骤 2 中的图像 2,2
    • Slide the spudger along the perimeter of the device to fully separate the two pieces.
  3. HKC P776A Digitizer Replacement, Separating the Screen and the Digitizer: 步骤 3 中的图像 1,2 HKC P776A Digitizer Replacement, Separating the Screen and the Digitizer: 步骤 3 中的图像 2,2
    • Use your fingers to pop the screen out from the digitizer.
  4. HKC P776A Digitizer Replacement, Removing the Cable from the Motherboard: 步骤 4 中的图像 1,2 HKC P776A Digitizer Replacement, Removing the Cable from the Motherboard: 步骤 4 中的图像 2,2
    • Use the tip of the spudger to release the latches on the motherboard.
  5. HKC P776A Digitizer Replacement: 步骤 5 中的图像 1,1
    • Remove the cable from the motherboard.
结论
Spencer Pheasant
于01/20/15注册
301 声望
创作了3篇指南
团队
USF Tampa, Team 7-6, Remmell Winter 2015 USF Tampa, Team 7-6, Remmell Winter 2015 的会员
USFT-REMMELL-W15S7G6
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 144
