跳转到主内容
HKC P776A Battery Replacement
你所需要的
  1. HKC P776A Battery Replacement, Separating Digitizer and Case: 步骤 1 中的图像 1,1
    • Insert the plastic opening tool between the digitizer and the case.
    • Place the spudger in the gap created by the plastic opening tool to assist in separation.
  2. HKC P776A Battery Replacement: 步骤 2 中的图像 1,2 HKC P776A Battery Replacement: 步骤 2 中的图像 2,2
    • Slide the spudger along the perimeter of the device to fully separate the two pieces.
  3. HKC P776A Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Insert the plastic opening tool between the battery and case.
    • Apply leverage to break the glue that is attaching the battery to the case.
  4. HKC P776A Battery Replacement: 步骤 4 中的图像 1,1
    • Continue breaking the glue along the perimeter of the battery until the battery can be removed.
    • Breaking all the glue between the battery and case may take a long time.
  5. HKC P776A Battery Replacement: 步骤 5 中的图像 1,2 HKC P776A Battery Replacement: 步骤 5 中的图像 2,2
    • Using the soldering iron, heat up the solder that is attaching the battery to the motheboard.
    • The heat from the soldering iron may cause personal injury or damage the internal components of the tablet.
  6. HKC P776A Battery Replacement: 步骤 6 中的图像 1,1
    • Suck up the leftover solder using the desoldering pump.
    • Remove the battery from the motherboard.
结论
Ryan Gornati
于01/22/15注册
409 声望
创作了4篇指南
团队
USF Tampa, Team 7-6, Remmell Winter 2015 USF Tampa, Team 7-6, Remmell Winter 2015 的会员
USFT-REMMELL-W15S7G6
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 633
