跳转到主内容
HAMILTON C-1 Bacterial Filter Replacement (Dual Limb Circuit Setup)
医疗设备
ifixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
  1. HAMILTON C-1 Bacterial Filter Replacement (Dual Limb Circuit Setup), Bacterial Filter: 步骤 1 中的图像 1,1
    • Orient Hamilton-C1 so the right side of the device is facing you.
  2. HAMILTON C-1 Bacterial Filter Replacement (Dual Limb Circuit Setup): 步骤 2 中的图像 1,1
    • Disconnect used/contaminated INSPIRATORY bacterial filter from circuit setup
    • Gently twist and pull the used/contaminated bacterial filter from the inspiratory outlet.
    • Next, twist and pull the used/contaminated bacterial filter from the inspiratory limb.
    • The used/contaminated bacterial filter should now be removed from the inspiratory port.
    • In reassembly, a new/non-contaminated INSPIRATORY bacterial filter will be used for this step. In addition, use a twist and pushing motion instead.
  3. HAMILTON C-1 Bacterial Filter Replacement (Dual Limb Circuit Setup): 步骤 3 中的图像 1,1
    • Disconnect used/contaminated EXPIRATORY bacterial filter from circuit setup
    • Gently twist and pull the used/contaminated bacterial filter from the expiratory outlet.
    • Next, twist and pull the used/contaminated bacterial filter from the expiratory limb.
    • The used/contaminated bacterial filter should now be removed from the expiratory port.
    • In reassembly, a new/non-contaminated EXPIRATORY bacterial filter will be used for this step. In addition, use a twist and pushing motion instead.
  4. HAMILTON C-1 Bacterial Filter Replacement (Dual Limb Circuit Setup): 步骤 4 中的图像 1,1
    • Your two new bacterial filters should now be installed in their respective inspiratory and expiratory ports.
    • After completing all steps, the end result should look like this:
结论
Luisa Chiu
于04/06/20注册
205 声望
创作了2篇指南
团队
Cal Poly, Team S7-G11, Paton Spring 2020 Cal Poly, Team S7-G11, Paton Spring 2020 的会员
CPSU-PATON-S20S7G11
2 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 358
