跳转到主内容
HAMILTON C-1 Bacterial Filter Replacement (Coaxial Circuit Setup)
医疗设备
ifixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
  1. HAMILTON C-1 Bacterial Filter Replacement (Coaxial Circuit Setup), Bacterial Filter: 步骤 1 中的图像 1,1
    • Orient Hamilton-C1 so the right side of the device is facing you.
  2. HAMILTON C-1 Bacterial Filter Replacement (Coaxial Circuit Setup): 步骤 2 中的图像 1,1
    • Disconnect HME (heat and moisture exchanger) and flex tube
    • Bacterial filter is held within the HME.
    • Use both hands to gently pull and/or twist the flex tube and HME away from one another until fully disconnected.
    • The HME should still be connected to the overall circuit setup.
    • In reassembly, a new HME with a non-contaminated bacterial filter will be reconnected to the flex tube for this step.
  3. HAMILTON C-1 Bacterial Filter Replacement (Coaxial Circuit Setup): 步骤 3 中的图像 1,1
    • Disconnect HME and circuit setup
    • Use both hands to gently pull and/or twist the flow sensor and HME away from one another until fully disconnected.
    • The HME (with used/contaminated bacterial filter) should now be completely disconnected from all parts.
    • In reassembly, a new HME with a non-contaminated bacterial filter will be reconnected to the flow sensor for this step.
结论
Luisa Chiu
于04/06/20注册
205 声望
创作了2篇指南
团队
Cal Poly, Team S7-G11, Paton Spring 2020 Cal Poly, Team S7-G11, Paton Spring 2020 的会员
CPSU-PATON-S20S7G11
2 名成员
创作了6篇指南
一条评论
Okay how offen should change out a carbon filter?
Bill Mcleod - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 14
总计 702
