简介
Applies to H4D engine only.
This is a simple method of cleaning the throttle body without removing it. It is sufficient in most cases and offers remarkable results. Because of its simplicity and the short time it takes, it is advisable to carry out this operation every time the air filter is changed.
The vehicle must be on a slight upward slope or slightly elevated so that the front is tilted upwards and the rear (engine) is tilted downwards.
The aim is to allow fluid and impurities to drain naturally from the throttle body.
你所需要的
Unscrew the 6 T50 screws by hand or using a wrench and a socket.
Lift and put aside the engine hood.
Using a screwdriver, loosen the two Torx T25 screws on the air filter cover.
Remove the cover by moving it forward and then lifting it.
Disconnect the oil vapour breather.
Loosen the hose clamp on the pipe leading to the throttle body using a flathead screwdriver.
Remove the pipe and airbox cover. Set the filter aside if it is to be used again later.
Spray brake or contact cleaner on the throttle and use a soaked paper towel to clean it until the body and edges are clean.
Allow to dry for a few minutes before refitting the airbox.
Replace the pipe as far as it will go.
Tighten the clamp screw with a flathead screwdriver while holding the pipe in its correct position.
Reinstall the air filter.
Replace the cover by sliding it towards the notches.
Re-tighten the two Torx T25 screws while maintaining slight pressure on the cover.
Once the engine is stable, carry out a test drive. The results presented below are ideal and there is no guarantee that all of them will be achieved.
Engine behaviour, particularly at low revs and idling, may become smoother. The idle speed may drop more quickly and become more stable.
Vibrations are reduced when restarting at stop signs, red lights and when maneuvering on wet/icy roads.
Better engine response when the clutch is re-applied and during restart: beneficial for heel-toe shifting.
Congratulations ! You have just cleaned your throttle body !
另外一个人完成了本指南。
由衷感谢以下译者:
92%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
2条评论
En effet vous avez raison ! Je vais préciser que ce tutoriel est uniquement applicable au moteur H4D.
