跳转到主内容
Greist Buttonholer Button Template Replacement
  1. Greist Buttonholer Button Template Replacement, Preparing the Buttonholer: 步骤 1 中的图像 1,2 Greist Buttonholer Button Template Replacement, Preparing the Buttonholer: 步骤 1 中的图像 2,2
    • Turn the adjusting knob to the right until the cloth clamp is extended as far as it can go.
  2. Greist Buttonholer Button Template Replacement, Open the Retainer Plate: 步骤 2 中的图像 1,2 Greist Buttonholer Button Template Replacement, Open the Retainer Plate: 步骤 2 中的图像 2,2
    • Located on the bottom, pull the lip of the retainer plate away from The Buttonholer, and then open the plate.
  3. Greist Buttonholer Button Template Replacement, Remove the Template: 步骤 3 中的图像 1,2 Greist Buttonholer Button Template Replacement, Remove the Template: 步骤 3 中的图像 2,2
    • Since the clamp is extended as far as it can go, the template should come out easily.
  4. Greist Buttonholer Button Template Replacement, Choose a New Template: 步骤 4 中的图像 1,2 Greist Buttonholer Button Template Replacement, Choose a New Template: 步骤 4 中的图像 2,2
    • 4 additional templates are included with The Buttonholer. Each template creates a different size button hole.
    • If you are unsure which template is right for your project, check the back of each template for the diameter of the holes that they make.
  5. Greist Buttonholer Button Template Replacement, Insert the New Template: 步骤 5 中的图像 1,2 Greist Buttonholer Button Template Replacement, Insert the New Template: 步骤 5 中的图像 2,2
    • Place the template into The Buttonholer, and then close the retainer plate.
结论
另外一个人完成了本指南。
Michael Sykes
于10/06/14注册
552 声望
创作了5篇指南
团队
USF Tampa, Team 3-6, Brown Fall 2014 USF Tampa, Team 3-6, Brown Fall 2014 的会员
USFT-BROWN-F14S3G6
5 名成员
创作了8篇指南
1指南评论
I had to use the reduction knob so the fabric holder was not fully extended to open the plate. So play with it. Better lighting on the unit once it was upside down and dark would have been helpful. But I did manage with this and the booklet. thank you.
Marcy - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 518
